anyone keen for and ARX, only $4000 at the moment
Im sure this is the car that is owned by a crash shop guy around the corner from my work. I see it every day at his crash shop as Im going to work, then a few weeks agoI seen it sitting there looking like this.
Well it must be an easy repair if a panel shop worker won't touch it...
Best kept... Yeah, except the smashed in front corner.
"Titanic; one of the best kept examples of 19th century ship building. Only crashed into one iceberg, superficial damage; easy repair..."
^^ LOL ^^
When he says "light damage' he must be referring to the actual head light being damaged (actually missing). The rest is more like "moderate damage" and I think more expensive to repair then he is making out.
lol..
nah seriously.
im starting to put money aside and maybe in 3 months might put this up for sale.
ive always wanted to get into a 32 R since i was small, have been looking at a few as of late, and im getting interested.
lol..
nah seriously.
I've been doing the same thing lately. Over here in W.A we don't get that many really nice examples so I've had my eye on this one, I love ths car!:
http://www.carsales.com.au/all-cars/private/details.aspx?R=10959085&__sid=12BA56AF125A&__Qpb=1&Cr=0&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&keywords=&__N=1216%201246%201247%201252%201282%204294963846%204294963593%20399%20447%20904&PriceFrom=399&PriceTo=447&seot=1&tsrc=allcarhome&__Nne=15&trecs=4&silo=1011
lucky bastard...wish I could get a 2 door car :glare:
lol your fault you couldnt keep it in your pants lol
http://www.carsales....ecs=4&silo=1011
yeh lol thats interesting.
but i want a faily stock one(if I can find it) dont wanna modify it or anything.
but just want one coz its the first car ive ever wanted.
Scotts already trying to talk me out of an RB lol :laugh:
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
