I wouldnt worry about that. Some mates were trying to convince me I didnt need a 70-200 2.8 IS, so leant me a non IS. Brilliant bit of glass. My next purchase for sure.
Seen those, look nice. Although considering how small and light it is Id ditch the lenses and get a nice flexible zoom lens.
Youre a sick man Craig... Go talk to your wife then!
fkn lol ryan you havnt been around long enough me thinks hahahahah
Yeah, I'm getting by without the IS - the only shaky shots I've shot so far were indoors at a Uni graduation where I didn't think it would be curteous to use a flash and I was a long way away at the back of the hall, and there were too many people around to set up a tripod.
nick you should get the 70-200 F4, its lighter, and smaller too.
Nah, I'm liking this lens more and more as I use it, and I like the extra stop of light, as well as the DoF. Can't afford another lens for a while, anyway. I'm just going to put up with the weight.
whats that LOL and how does it differ ?
you wouldnt be using it at such a large aperture anyway?
i run mine around F7.1 anyway. so wouldnt matter anyway.
Yeah, but sometimes I like to shoot wide open. And it's about options - it's always good to have options, right?
To be fair, chances are your flash wouldnt have been able to throw sufficient light to assist you here any how :P
Maxed out your usable ISO range already? Very much a rock and a hard place situation if you had :(
Yeah, no doubt.
Yep, ISO was maxed out, I should see how much I can recover it - it was mega-grainy.
just use a noise reduction program. sometimes they work well. i guess it comes down to how noisy your camera is at whatever ISO youre using.
get a 580ex speedlite, its got 200mm zoom (i think)
Ive seen Noise Ninja do some fairly amazing things. Smart software.
If Nick has a crop body & his lens was at 200mm then even the 580 wouldnt help - as he'd technically be at 320mm. Ive never shot with a monopod, but under those sort of circumstances it might work well..?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
