Hey everyone just a shout out to Scott another awesome dump pipe received, this one across the ditch in NZ.
I have attached a couple of pics of the engines and turbo dumps I work with. ( hope this works)
Paul
Somebody is a railway Mech I thinks.... (right?)
This kind of thing is a pretty common sight for me. Not me in the photo, just a random interwebs pic.
Note right at the back of the motor there is a spare piston and rod. The engine casing is about 3 or 4 stories high...
Oh, its a Container ship motor. Heavy fuel oil.
Edited by PN-Mad
Paul
Nice pics Paul; cubes+boost = WIN!:cheers:
I've been out of the game a while (used to build V16 2 stroke GM Diesels and a bit of Paxman stuff) Things look to have moved on a little! What make is that V20?
What is it you do Alex? Never really thought to ask... Or are you just in it for the seamen?:3some:
Paul
Im glad your happy with it Paul. :thumbsup:
Yeah Alex, back in the rail for about a year now after a break doing allsorts of different things.
Things have moved on Dale I'm catching up now.The engine is German made by MTU 4.7 litres per cylinder 18:1 compression with 55 psi boost common rail injected 1800 rpm max. So in terms of a diesel they are a bit of a race engine.
Very nice; common rail and computer control was only becoming a reality in large engines as I was leaving that part of the industry. I did see some pretty interesting Turbo/superchargers with the GM stuff; but not those kind of boost numbers.
It was cool knowing the turbos I was balancing & building were turning at 80,000rpm with a 60 cm wide impeller. Some Napier turbo assemblies were 100,000+ rpm! All on a floating bearing too; no BB set ups.
What kind of power are they producing; I'm guessing in the 3000 odd HP bracket?
Yep pretty much on the button with the horsepower 2700 quoted.We still have a few GM power plants but phasing them out slowly, they have been great work horses.
Good stuff. Looking forward to what you've got in store for the Stagea.thumbsup.gif
Hopefully picking my car up from All Type Crash this afternoon.
Aero wing painted, Xanadu grille painted, detail including brush touch up all round. It's hard to know where to stop spending money on bodywork though - there is a very minor dent in the passenger door. I could get it pulled out, but I'll be forever freaking out about some tosser denting the door again. I always park at the opposite end of the car park or take the end park, but people always manage to get way too close still. :rolleyes:
Go and talk to your local Paintless dent removal specialist; ask them if they'll do a cash job if you remove all the trim from the door. A lot of the time it's just the gesture that they appreciate.thumbsup.gif
I had 3 small pin dents done by a great PDR guy in my area for $60.
I'd thought about this but apparently the good local guy has recently retired. Need to scout out someone decent I guess.
  • 3 weeks later...
Rob from sinergy motorsports (adl) drive car [2005 axis/chocolate interior/v36 brakes] Thought it was pretty cool and I'd take some pics (havent seen a series 2 axis) .....don't know about the eyelids<BR><BR>post-41430-0-23872100-1321853747_thumb.jpg post-41430-0-03090400-1321853765_thumb.jpg
Edited by MOUTH
hmmm... wonder how he got that complied?
Looks good.
Still, wouldn't get any interior but black.
Northshore.... as a favour I hear (still cost them though).
EDIT: actually I think that was for a QLD based yard, but Northshore are offering compliance for other importers and have been for a few months now.
Oh and while I gotcha Alex, regardless of the instructions, you don't need to remove the rear water pipe when installing the kit.
Edited by iamhe77
Thanks Cam,
I think I saw it online in a QLD lot.
Thanks for the pro tip. That means the pathfinder cooling mod might just work then. How far through are you guys? before/after dyno? What did a GT-8 pull NA?
Looks good.
I agree black is nicer, Redicorp/pvp imports/sinergy motorsport in adelaide can comply m35's, they are on the raws list for m35s...i thought, god knows about 2005 axis model though :unsure:
http://raws.infrastructure.gov.au/rawswebpublic/rawpubmain.asp
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
