can get a remap for 200kw + more torques + faster dsg, while under warranty thats probably all ill do.
ive really wanted a new(ish) car for a long time. ended up with an actual new car. it has everything, except electric seats which is really weird
WTF dude?
So now that you sell your Stagea, you don't understand torque measurements?
Can't have more torques. Your engine has torque and the measurement of this torque is in nm, lbs/ft etc. geek.gif
Sound as silly a Clarkson when he talks about "torques".
On an unrelated note, I wonder if Craig will crack 300 powers when his car is finished...
So, just bought the replacement for the stagea. Dont laugh!
Got it brand new, collect Friday.
147KW petrol with DSG. Mines a sedan, not a wagon shown in this pic. Same colour!
Does Dsg chip second?
I replaced my Stagea with a 130i. Black. Msport. 195kw.
Needs an LSD.
Euro ftw!
i dont know, i pick it up in 2 hours. give me a few weeks to bed the motor in and ill let you know!
im gonna say no, its very smooth with its gear changes, you barely even notice it at low speed!
Use a good quality masking tape and take your time putting it up :)
Cheap masking tape can either leave sticky residue or come apart when removing leading to unnecessary anger.
Nice avatar change by the way. Do love (and will miss) those Nismo tips thumbsup.gif
Also, if you're masking against a colour; paint the edge of the tape with the colour that is underneath the masking tape. This seals the edge of the tape stopping the new colur bleeding under the tape and gives you a razor sharp edge.
I f**king hate painting.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
