took out my coilovers and put in standard suspension, rides like a 4x4 to go over the pits,
failed because of my eyelids, i knew it anyways forgot to take them off, and because of my tint
i have 8% light through the rear two doors and 13% in the front doors, aparently i have to take all the tint off the car, dont know how i can do it... i also found out that they tinted over the factory glass, well will see what happens....
sigh so annoyed
least the guy didnt waste my time and told me what to fix before he "inspected it properly"
sigh so annoyed
Is your tint just the factory tint or does it look heavier? From what I understand the factory tint should be fine :s
Not something I did to my car (engine is still out of it) but what I did today:
went to Tauranga for an SDU (Skylines Down Under) dyno day. In the awd turbo class an R32 GTR made 501awkw, an R33 GTR made 381awkw and a 260RS Stagea was third with a first run of 300awkw on 14psi and on 18 psi made 324awkw (for those who remember Psymin's Stagea it is no more - he is putting all the good running gear in an R32 GTR and the car is for sale with an RB26... pretty much stock RS260).
A 4wd V8 Adventra made 228awkw!
Friday, i fitted new clarion HU and Gizzmo EBC, removed split dumps, front pipe, hi flow cat and GCG turbo off my written off r32. Yesterday i fitted split dumps and hi flow to me new stag. Have my Nistune board here, just waiting for another ECU i bought from perth to arrive, then ill fit my nistune, hi flow GCG, z32 AFM (off the r32) silicon intake pipe and tech edge wide band O2 sensor.
Then i need to sell my r32 (repairable write off, has nistune, injectors, coils and so on already fitted) to fund intercooler, injectors and coils for the stag.
Looking good...
Funniest night in history last night
finished work,went to kidafa's place to help them finish his manual conversion
all was well
took it for a spin round the block,runs really good
started heading home,and as I boosted past chris to turn off my way home I blew off an intercooler pipes.awesome
luckily chris had mike and Adam in his car and they pulled over to help
was f**ken bucketing down and we had no tools to fix the popped hose
another sau member was randomly driving past and pulled over to help
he went back to his place that was just up the road to get tools,he got back and after some swearing and mike putting water down my arse crack I got the pipe back on and tight
only to find that my battery had gone flat.thanks for jinxing me Adam!
Had jumper leads in the car so sau random did a u turn to get our cars end to end,but his hybrid pos wasn't starting my car
he starts reversing back up the portrush rd only to be pulled over by the fuzz on patrol!
Got a warning,and breatho'd and he headed home again to get a jumper pack
so us 4 clowns are standing on the footpath waiting for him to get back and got f**ken egged by a car full of douches,who carries eggs these days and pelts stranded people? Teats
anyways,finally got my green machine running and headed home. But an hour and a half standing in the rain and with my window stuck half open my interior and Gtr seats are sopping wet...
Thanks to all the lads for sticking around
big ups mike,chris and chef
I'd have been f**ked without you!
And of course thanks to the random sau good Samaritan for the tools and jump pack
ps chris,that's why you should dress appropriately.put some pants and a f**ken jumper on!
And that's my story,and mike wonders why I want to sell my stag...
Finally got to have a decent drive after fitting the front facing plenum. It still runs lumpy when cold but after that smooth as. Did 460ks on about 3/4 tank. Best I have ever got.
Also while away picked up a pair of front guards, front bar with lip and some skirts. $50. They are spares jic.
all was well
that was me haha :D
civic repz
On blowing IC hoses. During testing after fitting the front mount and running huge boost, the hoses kept blowing off the straight pieces of pipe, did not matter how tight the clamps. Simple solution was to drill 4 holes and fit self tappers. The heads stopped the clamp from slipping the same as a lip or ring of weld. Easy to do and inexpensive.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
