Picked up the stag after new plenum install.
Sex!
Just ran a rag over it, so she's not detailed properly :)
Is that my throttle cable???????????????????
Why 66, yes it is! And its thanks to you I have the stag now :))
Incidently are the cam covers polished or chromed? My Gready look alike is chromed so i want the covers to look the same.
thanks mate, havent seen u for a while, and im on 2 weeks hols atm too so it will be a little while...though maybe not looking
forward to the roughness of annangrove road :)
Yeh it has been a while, Annangrove road is shocking at the moment i have been leaving the skyline at home most days and using the daily hack, hope they fix it soon.
badly when it rains down that road it looks like a mine field....
hi flow turbo and WB o2 sensor is in, max tp limit so no more fuel cut, pulled some fuel out, added a few degrees of timing and now its standing up when floored. Damn AFM is maxing out now though, will put my z32 one on tomorrow.
Also noticed when i took the standard turbo off that the impellor is all chipped, explains the noise when it was on full boost, (i was chasing a boost leak, it sounded like air squeeling). Looks like it wont be going back on the r32.
Whilst loading a case of beer into my garage beer fridge, accidentally dropped one on the floor. Bottle hits the ground, smashes, then to add insult to spilt beer, the broken end with the cap still attached, bounces 5 feet, hits the door of the Stag and put 3 little scratches on it!
F##k this for a game of soldiers, going to drink a few of his mates, that'll learn 'em...
found out why it whines on high boost :worship:
getting the turbo off was not the most enjoyable job tho
will fit the new gasket tmrw and bolt the 3inch dump up
also, lolz at the stock dump pipe, i'm surprised that the wastegate can even open
i also have a sneaking suspicion that the rest of my exhaust is 3.5 inch cos the front pipe on my car is a bit bigger that the 3 inch dump/front pipe i have and it necks down just before the dump->front flange
So after having my replacement engine in for a few weeks with a hi-flow on it, it is now back to a rebuilt std turbo, (my old one) with a ceramic impeller. The difference is HUGE. The hi-flow didn't come on until 3200 rpm. It was at max boost at about 3700rpm. The newly rebuilt std turbo is on boost even lower than it was before the engine was replaced. It starts coming on a 2200 rpm and pulls hard to about 6000. The car now has a Nistune and will be tuned before the weekend. The hi-flow was not for me, that's for sure. It was slower than my wife's Maxima, until it got to about 60kph, then it was doing over 100 kph before you knew it..... crazy as far as I am concerned.
I'll post up the dyno sheet after it is done.
Edited by Appealing
Replaced the plugs in my Stag and replaced the coilpacks too. Checked the CAS timing and reset the ECU while I was at it. :D
Also chasing why my brakes makes this loudish acoustics noise when its moving backwards (rolling back or reversing). Makes no noise moving forward. Got new pads and bedded them in on the track. They were fine up until I had to reverse out of my driveway for the first time with them. NOTHING is rubbing the rotors except the pads.
Mine does the same thing.
Jetwreck gave me his old r32 disks complaining bitterly about the squeal they had but I must have put them in backwards. ;)
Should have tried swapping them Craig...
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
    • That is porn and I wish I could do it easily on my streeter.
    • Yes there is a front and back insertion point on each side, each point is tubed with supports into the car and tied to the cage/ floor mount point
