Well last week the m35 was fiited with a custom 3inch stainless full exhaust, high flow cat, and magflow muffler. As a result, i now need a boost controller to keep check on boost levels. this is booked in for next week. I have also replaced the stock 17' rims with much better 19's. and plan new suspension with the intention of lowering the car. if any one knows what suspension works on the 2001 rs4's can you please let me know!
Edited by bechopps
Pics please?
I have BC coilovers in my NM35, height preload and damper adjustable for around $1200 -$1300. Will run from stock height to snow plow. But there are quite a few other options. Good luck!
I went to see Sam, RED513 yesterday. It is nice to talk with like minded souls.
Anyway I took the plenum off today and secured all the water lines as Sam suggested. Tomorrow I will relocate the fuel filter and relocate the relocated oil filter. Also give the cold start a good clean and clean the injectors.
I buggered the plenum gasket so will get a new one Tuesday. Hols tomorrow. Then its back together Wednesday.
Cleaned and polished headlights. Lots of japanese air grime came off. I think i might need to do it again soon though. Whilst rinsing, i noticed i missed a little bit. Have to do it once i regain strength in my arm (damn circular motion)
picked up 3" mild steel exhaust cat back from an R32 member and fitted it up - drove around for a day before deciding it was too loud and the drone was killing me...
Went to hitech mufflers and after being ripped a new one by lambros I now have a 3" stainless steel dual tip exhaust which sounds much nicer.... still need to replace the mid muffler as its still a bit loud for me...
Anybody else find their aftermarket exhaust is droney around the 2k range??
Yep, I do.
It doesn't matter how many resonators you fit, it wont cut down the drone. You need a large body muffler fitted to remove that frequency.
If you check out the Japanese full systems they have some weird ways of getting around the drone with dead end mufflers etc.
Nope.
Fujitsubo Legalis FTW! :D
Yep, I do.
The Legalis has a "dead nd" resonator which I assume is the reason for the lack of drone.
Brilliant design which has impressed more than one exhaust "professional" lol
Edited by iamhe77
Nope.
Fujitsubo Legalis FTW! :P
you mean there's two of me!!!! :D
Yep, I do.
Im starting to think I should of just forked out for an off the shelf jap exhaust... Unfortunately its too late for me to turn back now!! Large body muffler? WHich part are you referring to? the mid muffler? Any brand / size you can recommend?
Just recived my BC coilovers and fitted 2 out of the four, ( my friend want to have a look at them before i can fit them all )
just a word of warning, dont pull the original BC box out of the delivery box because sometimes its not taped up which means every thing lands on the floor and your nice shinny coilovers are now scratched
and chipped :thumbsup:
just need to get some wheels and its back on the road :)
ps anyone have a set of instruction for these things? yes mine didnt come with
Any Jap Jasma labeled exhaust is perfect as it has passed their noise test laws at the factory.
Its just the muffler you need to replace, the larger the body the more it will dampen the drone noise. I havent found any suitable ones in Australia yet, They seem to cater to the Ford and Holden crowd that want a nice rumble. I will probably make my own when the time comes.
Punk72, I have the BC's fitted to my M35 but they didn't come with instructions mate, they didn't even fit, I had to modify them. How was your install?
and chipped :)
just need to get some wheels and its back on the road :D
if you need a hand let me know and i can come round and tell you what i know
i've adjusted a few coilovers b4 but im no pro, if you get everything setup near to how you want it just take it to a good suspension place and get a 4 wheel alingnment done
scotty nm35 yeah they fitted really easy 10 min on each and they are in, I was just cleaning up all the boxes they came in and i found the instruction, they must have fallen out with everything else.
They are set about 60mm to short so i have got a fair bit of adjusting to do.
pipster11 Its going to be a couple of weeks before i get the wheels organised so i should have it all sorted by then. thanks any way, doesnt mean we cant catch up so i can show off the setup :D
cheers
and chipped :)
id be very interested to get some impressions from you about these coilovers as im thinking of buying a set for my gtr. they look like to good value for money to not at least try them out
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
