  Appealing said:
So after having my replacement engine in for a few weeks with a hi-flow on it, it is now back to a rebuilt std turbo, (my old one) with a ceramic impeller. The difference is HUGE. The hi-flow didn't come on until 3200 rpm. It was at max boost at about 3700rpm. The newly rebuilt std turbo is on boost even lower than it was before the engine was replaced. It starts coming on a 2200 rpm and pulls hard to about 6000. The car now has a Nistune and will be tuned before the weekend. The hi-flow was not for me, that's for sure. It was slower than my wife's Maxima, until it got to about 60kph, then it was doing over 100 kph before you knew it..... crazy as far as I am concerned.
I'll post up the dyno sheet after it is done.
Should have left it on and wound the boost up John like we discussed.. laggy highflow and only running 7psi means you get all the crap lag of a big turbo and none of the fun :) it was also running the stock tune so you really can't expect much..
With VCT working my highflow is making 15psi by 3500rpm and now that I don't have a hole in my cooler pipe it pulls much harder :)
Did you put that split dump pipe on?
Edited by bubba
What hi-flow were you using? My GCG highflow in conjunction with the Jaycar IEBC gave me 10psi by 2500 rev/min and 15psi about 3500.
Do you have a full turbo back exhaust?
Edit: oh Kiwi, yours is a 33 turbo so I'm not surprised yours is on song a little sooner than our 34 hiflows.
Edited by bubba
3 inch dump is on
can't really notice much difference tho
and even after replacing the turbo-maifold gasket there is still the whine on boost
turbo had a bit of play in it so its probably that
:P
if only a side exit pipe was road legal
  kidafa said:
Yess free-reving to red line while cold, peanut.
stock gauge doesn't move off its stop till about 60掳C, motor was at about 55 according to ecutalk
and its not like i was bouncing of the limiter
and i run a group 5 synthetic which is pretty sticky even when cold
and its probably been done to everyones motor in jap land
Oh pippy
what can I say
as chris mentioned,your quite the variety of a bad nut
you could of atleast put up a vid of you launching down a quiet suburban street on the limiter with just a dumpy on...
Once you warmed it up of course!!!
  M I K E said:
it still had cold start idle lol
im still looking into why my car does that
i do a lot of short trips and even once the car warms up it holds the revs up for about 5 secs b4 letting them back down every time you start it regardless of whether or not its hot or cold
do you guys hate youtube or something? cos i swear that every time someone posts a vid up you two criticise the poster about something
Sorry mate but I do believe the last clown put up a video of a stagea frying the shit out of his tyres <---- Idiot
And then you giving it stick while cold <---- Idiot
Both happened to be bannan yellow wagonws to, i can see a pattern here
Back on topic ...
Changed AFM over with a loaned AFM to try and resolve why my stag hits a 5,000rpm limiter ... misfires all over the place. But didn't eliminate the problem.
I've been going thru the elimination process with:
checked cas timing
replaced plugs and gap
replaced coilpacks
replaced air filter
replaced fuel filter
replaced O2 sensor
replaced MAF
Checked all old plugs and they were an even, nice colour. My A/F Ratio meter is telling me the mixtures are rich up top. But I've touched nothing since my last tune. Try a few more things, then I'll just throw it to the tuners. Hoping to save myself some $$$ first.
On the weekend, I'm also going to check the compression in each cylinder for the hell of it.
Not sure about the stageas, but i know the 300zx has a neutral wire to the ecu that causes the ECU to limit RPM when car is in neutral, to stop engine being overly free revved.
Might be worth checking out.
  RubyRS4 said:
Back on topic ...
checked cas timing
replaced coilpacks
replaced air filter
replaced O2 sensor
replaced MAF
That might be the most useful input I've had yet.
I've converted my AT Stagea to manual. Is there a chance something in the ecu is causing the misfire (limiting revs) because I fooled the ecu to thinking the car is in neutral so I can start it?
EDIT: scratch that ... I've had the car on the dyno twice since the manual conversion and its definitely revved past 5,000rpm without problems before.
Just had a look, pin 39 is the neutral pin. As i said, im not sure if the stageas do it but i know for certain that the 300zx's do.
http://www.skylinesaustralia.com/forums/po...087-R34-ecu.pdf
ok, lol just seen your edit
Edited by kjb_r33
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
