Sounds like you cooked the starter, doesn't take long to kill it.
Could be your fuel pump, or possibly the immobiliser causing the original issue?
hey mate.. gave it the 12volt jump with flathead as it was on a bastard steep angle at the bottom of the driveway , probably cooking it further , but least i got it to the top of the driveway.. so its definately starter.
i can access it fine from the top of the driveway now, and can get it out easy enough with stands and the trolley jack and most likely passenger wheel off.
any recommendations on replacement or rebuild?
v35 - cheaper compatible?
any ideas would be appreciated.
Edited by PetroDola
motor out to fix the sump
now thats 300zx talk :)
lucky it didn't happen on the road, could have been very messy and even dangerous. are you worried that after you fix it all up its just going to do it again at a later date?
well not really. we are going to pull the plate out and machine some grooves into it for sealant (factory sump has this, 3l adaptor plate does not).
also....its just a daily not a race car. it will never spend 15min at 6000rpm like it does on the dyno,
fingers crossed it will be ok....but I will be struggling to have it back on the road by xmas
lol at Josh's comment. Engine out. Shattered duncan, but couldve definately been worse. Pays to have an oil pressure guage.
Not much luck lately with the stag. The electrical surge then this. Just drive one of your other five cars for now mate. :)
Edited by dirtyRS4
almost killed mine.
was running hard on the dyno being tuned when oil pressure light came on. investigation underneath shows hge leak from the sump.
it appears the proengines 3l adapter plate expands at a different rate to the block, resulting in the sealer breaking and a major leak.
Duncan do you know what material your adapter is made of? I have an adapter which is only the second from this particular supplier (2/3 the cost of the RIPs one) so I am wondering if I should be worried about a similar failure.
no, not sure exactly what it is....only that it clearly is not right. And now that I have mentioned I have had people coming out of the woodwork with the same issue :rofl2: will follow up with the maker though
pretty sure no real damage was done, we will check the bearings while the motor is out but should be OK.
and funnily enough....I just bought a cube to use as a daily while the march is off the road getting a forged motor...guess it's going to be busy for a while.
Not sure if this will help you, here is one I have lying around. It has the sealant slots in it for reference
good to see they went to the trouble - who made that one?
I bought it from a guy in SA. When I asked him who designed it, he said it is "exactly" the same as the proengines one
So they must have copied it
Just checked the proengines web site and pic's, they have sealant slots on one side only?
http://www.proengines.com.au/sumpadapter.html
Does yours have none or one side?
I will have to check mine later.
hmm I will turn it over when I pull the motor....but I don't remember any slots. Bad news if it does have them because it leaks like a sieve.....will be harder to fix. Might simply not be flat as well, we will check it and mill it if necessary
What brand sealant was used
Aparently the genuine Nissan sealant is the ducks nuts and the only one that should be used.
I actually considered going to that, and then I remebered about the window licking special bus riding boble headed tricycle pilots that organise things at barbagello so I stayed away and went to a hot rod show instead :rofl2:
I actually considered going to that, and then I remebered about the window licking special bus riding boble headed tricycle pilots that organise things at barbagello so I stayed away and went to a hot rod show instead :P
Same, same. I had WW3 with the mrs on the way, so had to turn back and let her cool off in the spa. lol
Heard ppl lined up for 3 hours and piggaz were in force. Saw most on TV anyways, I still shouted abuse at webber from the comfort of home. Has bubba got back from shooting kunce in KL yet?
Nah, he fly's back in some time tomorrow apparently.
Fkn wimminz eh? I learned a long time ago not to even try and take She Who Must Be Obeyed to any car stuff. The only one we do together is the fathers day show in freo, and even then its only because the kids are adamant that we do something that dad wants to do, bless their little cotton socks :P
OK.....I'll bite.
Cooling
HDI FMIC
Phenolic runner spacer
Nismo low temp thermostat
Custom(fisher) 3" intake
V35 manual radiator
Twin Trans coolers
TB spacer(lol)
Powerduct( :action-smiley-069: )
catch can(s)
Turbo
High flow original to GT30/71
HDI EBC
Handling
Bilstein shocks
Eibach springs
324mm DBA rotor
R32GTR callipers with brackets
Hawk pads cut to size
Body
19" Lenso rims
R33 GTR N1 scoops
fully sic Nismo strips(custom fading :D )
eyelids
Exhaust
Dump pipe....some japanese one
Complete Exhaust from Charlstone
ECU
Haltech platinum interceptor.....soon to go for a replacement reflashed ECU
Interior
Twin headrest DVD players
DTV
English conversion
On the horizon
Sway bars
Custom Airbox Suction pipe setup
Brembo's
Paddleshift's
Gearbox rebuild with stage 2 shift, 3,500 stall(depends on reflash outcome) and MVB
Bonnet pin's so I can lock the bonnet closed and give the key to my wife to STOP ME!!!!!!!!!
Sweet ride mate!!!! I think I've done similar to you to my ARX apart from tricked up ECU and I'm running R34 wheels. By the way saw your in HPI magazine awhile ago. Great job!!!
Edited by KV2
well busy week ahead and busy week end just gone stealth fmic plumbed up 2Hrs with modifications to make it sit lower nismo front bar replaced 7Hrs trimming fit trimming fit sand ect :D all done now looks sweet will post up pics. this week 33 front brake conversion one night after work and friday of to mv automatics for shift kit :D friday night stag cruise. Gcg high flow sat in cupboard so just need injectors pump and comp now hmmm looks like xmas prezzies for the missus seems shes paying for the shift kit :D that should keep her all happy while the 25/30 gets built :action-smiley-069:
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
