awesome stuff Craig - glad to hear the black beast is back on the road :)
mad job in getting it there also.
its too damn far, and im not enough mods along to need a tune myself just yet lol
that said, i havent done an oil change in a while, with the nismo ecu still learning, i got 540km from the last tank of about 70L. thats with some spirited driving also. im pretty happy with the economy of this ecu even though i have a boat load more power/torque!
yeah 540kms wtf ;) --- im lucky to get 450 off boost :S
heh ive given up on mine in the sense of mods for the time being you guys are light years ahead even you Zei20l. ill be a year away from getting a tune and an ecu at this rate - its only destined to get a highflowed turbo for the time being and a new starter :)
ill do the runner spacer and new plugs and rocker gaskets when the turbo gets done. as i cant see myself in the limited space ive got doing engine outs often - until i get a bigger garage.
Edited by PetroDola
Spotted my tractor getting 520kms from 62 litres of 98
including going up Mt Tambourine with 5 large adults in the car
Also, c34 rear strut brace fabrication begins next week ;)
He drives like a pussy so no surprise... :) lol
LOL, if it wasn't for him quoting 70 litres, I would have thought he was giving us numbers for his wife's Fiat, not the Stagea. And that would be some serious thrashing of the little buzzbox, too (the car, not the wife ;) ).
Getting a 70+ litre fuel tank into the little Fiat would be a feat, the thing is so small!
Man, this thread is way too quiet. Oh and it always makes me hungry, regardless of if the last few posts contained chat about food or not.
We need Sean, Cyrus, Mr ClownShoesTangles and others to start posting again.
i rekon using the boot i could get 70L in there :)
FYI people, did 240km on 1/4 of a tank to Port Stevens ;) all highway but needed some serious throttle to get past some morons. yes, the wife commented on the car sounding like a plane when i give it a boot full!
i guess 500+ km from a tank isnt all that bad. it needs an oil change so i expect that to get a little better afterwards
need to do the manifold spacer at some stage. not to mention the 456428475840596845673486 suspension parts to go on as well. i wish i had time.............
boy`s must have eaten to many CHILLIES lol
FYI people, did 240km on 1/4 of a tank to Port Stevens :) all highway but needed some serious throttle to get past some morons. yes, the wife commented on the car sounding like a plane when i give it a boot full!
my m35 acheived regularly 650-700 ks out of a tank cruising mainly 110-115 kph over 5000ks sunny coast - melbourne and many places in between including up to mt hotham -bairnsdale-moe.
around the sunny coast 550-600 per tank 50/50 city-country driving. ;)
Fitted L/H tailgate lamp cluster. Interesting, the cluster I had was from a tailgate that did not have the closer fitted. The plug for the cluster is four pin on the closer model, but only three pin on the non closer. I experienced the same problem on the 25G while fitting a closer.
Why Mr Nissan????????
Now all the probs with the AFM are fixed have wound the boost up to 10psi.Will check it out Monday.
cant believe i am awake and its sunday... think its time to go wash the car...... f**k i have to get out of bed to do that also....
Wash car. whats that? I gotta stop fkn with my sig and shit. i keep forgetn to save. lol. no pm atm and default skin is shizenhousen. ftl
Admins did well with the db upgrade fck all downtime, but bringing across the pms will be the true task. checkn for integrity will be a PITA. Latency seems minimal. :thanks:
Edited by dirtyRS4
Admins bringing across the pms will be the true task. checkn for integrity will be a PITA.
LOL only way Your Car in washed is driven in RAIN :D,Give me a Buzz you slack Barcket :thanks:
Just got back from the Swan Valley chuckie. Will ring later on tonight. :nyaanyaa: whats with the post edits not disappearing? lol
Edited by dirtyRS4
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
