Funny noises coming from the front of my car, so I think some coil overs might be needed (either that or some ball joints/bushes are STUFFED) :rolleyes:
Sounds like a piece of gravel is in one of the shocks rubbing up and down as I go over bumps and corners.
Anyone got some coil overs they want to sell :D
I think i'm on my way to around 500K's to 70L (14L/100K)!!!
just get a set of BC coilovers from justjap. $1300 later (free delivery i think) and youll have fully adjustable suspension
but check bushes etc as if they are worn, youll probably make it worse with new suspension
Like this one?
Lol yeh like that one!.. smart ass haha
yup wicked economy!!
it does 0L/100mm :P
congrats on the emanage! i should really install mine one day. oh so many things still to install, and so little time :(
hahah
Thanks man!
but then you could confuse the issue more and introduce light penetration to the equation, as a higher kelvin rating increases the spectrum as well, which leads to an increase visibility, and difusion across a broad range of conditions (rain, fog etc etc)
Bought me an eManage Ultimate today with a universal harness for $676.00 Aud directly from Japan with free shipping.
oh.. its BRAND SPANKING NEW :D
Like this one?
* yawn *
Where's the originality guys? :P
fck all this hid bs. light penetration. lol. you should try and get out more dale. You be getn pwned in the wasteland by boz mang. i think he wants to buy teh fury off you.
I got one of those too... :cheers: Plus the Profec B boost controller. :thumbsup:
Just need the time and funds for a road trip.
Geeze, your car is going to be essentially a greddy showroom :P
/begin rant:
My first experience importing a Jap import has not been nice. I'm fixing every bloody thing on it. Doesn't anyone maintain their car anymore FFS?
Spark plugs were stuffed, I think the shocks are stuffed (pretty much a given though) or a ball joint is stuffed, but what really gets me is the STUPID bloody compliance place that did the RWC, DIDN'T FIND THIS OUT! I would've thought they had to check this out as it is a safety issue. Even if as part of the inspection they would say "you'd better change this soon - do you want us to do it??"
I don't even think they changed the oil...:angry:
/end rant.:rant:
PPS -eat shit Mundine. lol
the MOUTH IS NOT A BOXER just a wantbe ,want`s to try to be someone so that he could think he`s liked :whistling:
Mundine vs Woods
^^^ mama said knock you out. LOLburn khunt. he's a brawler and a farkn animal IMO. WTF would you know about boxing chuckie?
BTW I need your spare 350z rims mang- pronto. :thumbsup:
Edited by dirtyRS4
lad i went to school with was british school boy champ ,& as kid we watched all boxing on tv , used to love watch Don Curry ,you might be have seen him in 1980`s lol
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
