new rims and put all the stolen stuff back on. on that note does anyone have any stagea side skirts cheap
not sure if these are any good
http://www.japaneseimportspares.com.au/nissanstageaw34m35/3
Blacked out lights on a black car = awesome :)
nice one dude!! im considering doing it also, but on a silver car it wont be as good IMO
Honestly i've done it to a silver Hiace. and it actually looks really good against the silver if you dont do it so dark.
your meant to Clay it and polish it and it comes up all smooth like the paint on your car. but after time its fades n you have to do it again. Im gonna go n get it clear coated.. never fades.
yeh they've made a new product, coz i found this one better than the last time i used it on my supra.
maybe its the same as the RC Car stuff. ive got some of that too lol
I has epic new coffee. Harrar Estate in Ethipoia :thumbsup:
i get close to a full inch of crema on my esspresso cup, and there is enough caffeine in this bad boy to give a blue whale heart palpitations. The aroma was listed in the catalouge as having "notes of sweaty saddle, fungus and forrest floor"
fkn wut?
All I know is that its tasty as a mofo :woot:
Jase - I more meant that if you try and put chilli seedlings outside now they wil struggle like buggery. I always try and have my seedlings in pots before the beginning of december, so let me know how you go getting some started this late.
electric FTW!!! :P
lol i actually put a little turbine supercharger on it. the filter was connected to it. didnt add much performance, but looked pretty cool. Not so cool when i flew it off a jump and couldnt find the charger
Hello Guy`s ,
Would you PLEASE USE CHAT THEARD & NOT THIS THEARD TO CHAT,i come to see what`s happening with People`s Car`s & it CHAT ONLY :whistling: ,
Thankyou :thanks:
Trinidad scorpion seeds or cuttings.. YES PLEASE
All my chili plants died in the sub-zero temps the other month :( Had a Bhut Jolokia that was flowering, a Red Savina, a Jamaican Hot Yellow and a bunch of normal habaneros, jalapenos, thais etc :/
Picked up a 4-pack of healthy habaneros for $5 at Bunnings on the weekend.. might put them under a light :whistling:
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
