  On 16/12/2010 at 10:03 PM, Daleo said:
*Black Stagea now becomes invisible* nice one Aaron.
lol you have no Idea. not one person looked at me driving to work today
  On 16/12/2010 at 10:39 PM, zei20l said:
congrats dude
now you can legally drive it :P
lol Thanks man!
I spent my first 2 of my 3 years without P's up :) the only time I actually put them up is when they changed the law to green p's.. (and sent me some free ones ;] )
never got asked once! ( I didn't have a Stag at this time though)
  On 16/12/2010 at 4:19 PM, scotty nm35 said:
There is a good chance it is the rear of the passenger valve cover leaking, not the turbo. I guess you really want to remove it to check though, and highflow it while its out of course. :whistling:
LOL, shit so the engine needs to be out to fix that valve leak!?
can't afford highflow ATM...just bought the HDi IC, the exhaust, emanage, in a single week. Kinda feeling poor ATM.
And now I'm going to need new shocks. BC's are what? 1200? grrrrrrr
  On 16/12/2010 at 9:27 AM, Daleo said:
  On 16/12/2010 at 7:23 AM, scotty nm35 said:
Mine are midway, 15 clicks I think.
:blink: Faark, mine are 3 clicks in from full soft.
Yeah, but you have the RS kit and Scott has the VS kit... if that makes any difference
  On 16/12/2010 at 7:12 PM, AaronNM35 said:
i reckon those shocks are the cause of that noise if its leaking. :)
U reckon?
The previous owner was adamant that it's the BOV. this is what he said:
"It definitely is the blow off valve because when i blocked it off, the farting was eliminated straight away.
Here's a video i took of the car and how it sounded with the blow off valve blocked off.
No farting what so ever:"
http://www.youtube.com/watch?v=8GpaCCz3Wj0
Edited by ironpaw
hahaha VELCOME TO THE VORLD OF THE BLACK HOLLLLLLEEE!
Edited by AaronNM35
Engine shouldn't need to come out. If the turbo needs to come out, then it is probably easier to take out the engine, but also probably more time consuming.
If it is the valve cover, no way would you take the engine out to change the gasket.
Yeah, BC's are 1200-1300 plus shipping from JustJap... or there is a second-hand set of Nismo S-Tune floating around NSW :ph34r:
  On 16/12/2010 at 11:09 PM, ironpaw said:
U reckon?
http://www.youtube.c...h?v=8GpaCCz3Wj0
I cant view vids.
maybe it is a BOV or IC piping. maybe you'll fix it by changing to the HDI like scotty said!
Well now that my position at work has been made redundant (after 11 years service), I've got all the time in the world to work on the Stagea. I attacking all those 'little' things (knocks/rattles) that have been annoying me for a while. Getting an exhaust hanger rewelded today to give a bit more clearance to the tow bar; got new wheel studs to replace the dodgy/stripped ones I have; putting in my order today for larger injectors and a 3076. :D
This weekend I'm fitting a new timing belt and pulleys; along with relocating my oil temp, water temp, a/f, and boost gauges. Also shopping for new slotted rotors front and rear!
So much to do ... so much time to do it :P
Yeah I know, cept I have to wait for the owner to list it on the classifieds 1st...he did say no PM's!! :(
  • Like 1
bahahah iaiaiaiaiaiaiiaiaiiaain
  • Like 1
  On 17/12/2010 at 12:12 AM, zei20l said:
thank you for taking my advise
dont worry everyone ill be listing available parts. probably on another forum tho :P
Mind if we ask which forum that is?
Ahh hang on I think I know which one :thumbsup:
Edited by ironpaw
yeh that way things wont get deleted :)
  • Like 1
Cricket sux yes when your losing :whistling::nyaanyaa: + have SHIT CAPT & VICE CAPT,punter & pup :ban::spank::domokun:
well U2 might be but have to wait & see ,but be good to see friend`s over from MELB & enjoy a night out :cheers:
as iam old man don`t get out much :P ,
  • Nope 2
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
