cameron Posted February 14, 2004 Share Posted February 14, 2004 Hey, got a 95 Gtst with standard boost and the usuall front mount, exhaust, pod etc: any way we have a bad missfire, changed plugs, gaps, coils and it still occurs this is what its like. turn the car on works fine go for drive and so on. then turn car off and go for lunch and so on then come back and turn it back on it has a weird sort of idle it will gurgle and surg intill you give it a bit of throttle then it'll idle fine ? any way off we go then it will start missing some times at 3k and sometimes at 4krpm and it wont go over it, cause it was that bad. sometimes it'll have a little miss at about 4krpm then it'll pull to redline. other times it'll just work fine and not miss at all ??? it does this in all gears and even in neutral, doesnt matter how much throttle you give it even if you ease it on of put it flat it'll still miss bad. last month we had it missing really bad (on empty tank fuel) we had the bonnet up looking for leaks and reved it up it was missing then all of a sudden a huge bang(back fire)!!!! their was smoke everywere (white) it sounded like a gun shoot. it did that twice intill we went to the survo and put some petrol in it.... it worked fine after that didnt miss intill later on maby about 1 or 2hr's later it started missing again? Got some new NGK double platnim iridium tips in their and pulled plug number 6 out and it had a crack in it, it was black too.... and their only been their 3 weeks ??? the rest were fine. what could this be ? were are using an avc-r boost controller and it does it even if its off or on.... thanks in advance. Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/ Share on other sites More sharing options...
crooser Posted February 14, 2004 Share Posted February 14, 2004 swapping a known good AFM in + ecu reset would be my first try Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-686446 Share on other sites More sharing options...
red17 Posted February 14, 2004 Share Posted February 14, 2004 Nissan Air Flow Meter Syndrome - My car had precisely the same symptoms. I sprayed mine with electrical contact cleaner, fixed it. Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-686451 Share on other sites More sharing options...
cameron Posted February 15, 2004 Author Share Posted February 15, 2004 its not the air flow meter because we have tried another one and it still misses.... today its doing its really bad its missing when its ideling and it was running on 5 cylinders but then their was no miss through the rpm ? but then it started mising through rpm and it ram on 6 cylinders again ? weird.... it stalls a lot too when you push the clutch in 3rd or 4th gear and take your foot off the accelerator, the rpm just goes down to zero intill you take your foot off the clutch then it jump starts it self !!! hope you guys can come up with some answer cause its gettings quiet frustrating..... cheers, Cameron Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-687412 Share on other sites More sharing options...
predator Posted February 15, 2004 Share Posted February 15, 2004 errr... sounds like its detonating like a m/**er.. um, do you have any compression in cylinder #6 at all? you might want to check that little thing Cracked spark plug? thats not good at all! I wouldn't be driving it like that at all, sounds like serious problems with cylinder 6 cap'in. May already be too late... Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-687495 Share on other sites More sharing options...
cameron Posted February 16, 2004 Author Share Posted February 16, 2004 were thinking it might be an injector problem ??? Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-688446 Share on other sites More sharing options...
Guest RedLineGTR Posted February 16, 2004 Share Posted February 16, 2004 coil pack??? maybe the ground of them..i think thier was a thread about it a while ago or something similar use the search and see if you can find it. Rob Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-688452 Share on other sites More sharing options...
R34GTT Posted February 16, 2004 Share Posted February 16, 2004 coil pack??? maybe the ground of them..i think thier was a thread about it a while ago or something similar use the search and see if you can find it. Rob Me think this too. Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-688516 Share on other sites More sharing options...
cameron Posted February 16, 2004 Author Share Posted February 16, 2004 have searched and theirs nothing on fixing my problem... but their was some helpful hints we also have a lot of white smoke pouring out the exhaust when give it some and a little when ideling ? what do you mean by the ground of the coilpack ? Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-688540 Share on other sites More sharing options...
Guest RedLineGTR Posted February 16, 2004 Share Posted February 16, 2004 white smoke pouring out the exhaust dosent sound too good??? is this when its hot or cold?? Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-688550 Share on other sites More sharing options...
cameron Posted February 16, 2004 Author Share Posted February 16, 2004 both hot and cold.... Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-688622 Share on other sites More sharing options...
predator Posted February 16, 2004 Share Posted February 16, 2004 Like i said.. do a compression check! sounds like your engine is seriously buggered mate.. Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-688776 Share on other sites More sharing options...
predator Posted February 16, 2004 Share Posted February 16, 2004 you checked the radiator for evidence of oil in the coolant? Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-688783 Share on other sites More sharing options...
cameron Posted February 16, 2004 Author Share Posted February 16, 2004 when we took the turbo off all the coolent drained out of the water line and it was fine.. maby a little bit of oil not much though. we just took the air flow meter wires off and replaced them because they have been dogyed up with wires sticking out everwere.. and it wont start now... but when we unpluged it, it starts ??? but wont rev over a certain point can anyone help ? Thanks, Cameron Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-688840 Share on other sites More sharing options...
predator Posted February 16, 2004 Share Posted February 16, 2004 well sounds like you've screwed up the AFM rewiring then. Check again. Without an AFM it will start fine, just when you go to open loop mode over about 2500rpm it will refuse to rev past that without a correct AFM signal. Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-688861 Share on other sites More sharing options...
cameron Posted February 16, 2004 Author Share Posted February 16, 2004 yeah, any one got a diagram for the correct wiring ? we fixed the afm it was the earth wires... but it hasent fixed the miss common guys we need to know what this is because its so frustrating driving under 3000rpm Cheers Link to comment https://www.sau.com.au/forums/topic/34256-un-solved-miss-fire/#findComment-688883 Share on other sites More sharing options...
