just wondering how many of you out there this has happened to and how much damage you have done. the story goes first day at the track (haunted hills hill climb) get a good couple of pratice laps in then what we think at this point in time and after reading its a big end bearing wont know until we pull the engine out but yeah were pretty sure it has got oil in the head and run out of oil down the bottom from the car and the movement on the track and high revs. just wondering what you have done and what sumps everyone has used. i will be puttin one of those things on the back of the head to get the oil out but just wondering the best sump and where you have got them from and sort of price. also is the rev limiter bein set at 8 and a half to much revs
thanks
https://www.sau.com.au/forums/topic/342581-oil-in-head-big-end-bearing/
  • Replies 51
is it just me or this really hard to read. One of the longest sentences ever and hard to understand.......
+1
Oh, and search alot, this is well covered, including in a 40+ page thread on oil control for RBs...
I think it's the severe lack of punctuation.
sorry but i didnt know it was an english class cant read it or understand dont bother writing anything
It's hard to help you out when no one understands what you're asking.
sigh... no detail = fail.
what motor?
what mods?
also, you dont need external oil drain from the head. waste of time.
ill ask even though i probably know the answer...
did you overfill the sump by 1L like you should have?
what motor?
what mods?
Bingo bingo and bingo.
I went to all the trouble of doing the rear drain on cats car then tested it on the dyno..... even with it disconnected and running 7500 for close to 15sec (don't recommend this unless you own it :blink: ) is still stayed dry...
no it wasnt over filled by a litre
Well that’s your first problem. A big no-no.
acl bearings, cp pistons, ported and flowed head, n1 oil pump
This sounds like the second…
What oil control/restriction mods were done as a part of the rebuild?
I’m gonna take another ‘wild’ guess and say none?
Realistically you don't need a sump if you've done everything else correctly for that level of setup.
Plenty of people before you have been totally fine.
So the head to sump oil return line that people have been using for years and everyone always says to do it.... Is a total waste of time and money and dosent make any benefit what so ever??
Not one circuit GTR down here has one.
If everything is done right with block restrictions and so forth, then you don't need it.
If you did a list of people with them, and then without... it would be extremely one sided.
not everyone, just everyone that only reads one side to the oil control in RB thread
and not to say it doesnt work, just doesnt work the way people think it does
Edited by jangles
but the ones trying to disprove its function only claim how it works in what they have seen on the dyno
how can it be tested on a dyno when it is not subject to the same g forces being placed on the car like it would be if it was at the track
that and the fact that they dont use them and dont have issues,
maybe there should be one at the front of the head, so under heavy breaking all the oil rushes into the sump :D
maybe there should be one at the front of the head, so under heavy breaking all the oil rushes into the sump :down:
people run n1 pumps without issue too :D
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
