  • Replies 51
alright ill ask the question that no one has actually answered yet then. what sort of bigger sumps do you recommend? and where you have got them from? also what sort of price?
by putting that bigger sump on you arent fixing the problem, which is what you stated in your first post, youre just bandaiding it, which is the same as 1l overfill on track days..
we were trying to help you out with the other little points in your original post you made...
few other sumps,
http://www.performancemetalcraft.com.au/
http://www.lewisengines.com.au/category55_1.htm
well how do i fix it then. not a fan of over fillin the standard sump because that is something ya dont do with engines from what i have always been taught.
see below it is taken from the oil control thread posted earlier in this thread
i assume you didnt open the link as this is an extract fromt he first post in the thread
Circuit, drag or drift RB’s with excess oil in the cylinder head, not enough oil in the sump, oil in the catch can, wet sump, oil surge, lack of oil, big end bearing failure etc
On the circuit race cars we take a 5 step approach in controlling the amount of oil that is trapped in the cylinder head and/or blown into the catch can; :laugh:
1.Block off one oil feed in the block (RB26’s have this standard)
2.Fit an appropriately sized restrictor to the other feed. The size of the oil pump is one of the determinates for the size of the restrictor, ie; a high flow, high pressure pump needs a smaller restrictor. Constant higher RPM needs a smaller restrictor etc.
3. Fit an external oil return from the rear of the cylinder head to the sump
4. Drill out the oil return galleries in the head and block
5. Machine around the oil return galleries to facilitate access for the oil
It seems to me that many guys do #2, and some maybe #1. If you haven’t done #3, #4 or #5, then please remember that they are cylinder head off jobs. Drill out the oil return galleries in the head and block is pretty much self explanatory. As is machining (die grinder) around the oil return galleries to facilitate access for the oil to the return bgalleries. The external oil return fits to the rear of the cylinder head at the Y, there is a welsh plug there that you can remove and replace with a fitting. Then braided line to another fitting in the top of the LHS sump wing if you have one. If you don't, then you should for circuit and drift work.
in addition to a larger sump
well within your budget I would be doing:
enlarge oil returns in block and head
fit oil feed restrictor (based on flow of pump but between 1.1mm and 1.5mm depending on flow of pump, max rpm and type of use)
fit trust sump extension (best sump that still fits your budget, the others are good too but as you can see $1600 just for the sump extension) trust sump is a good design and holds plenty oil
do the rear head oil drain if you want. opinions are mixed on it's value but having one shouldn't hurt anything but they can make refitting the engine a bit of a pain depending on the exact design you may need to 'massage' the firewall to make it fit without touching.
that's the key bits.
So isn't that why you started the thread?
To be educated on it?
I think 6 people now have told you what needs to be done - and also the fact that putting a larger sump on wont necessarily fix the issue...
I certainly haven't been taught that you need external oil drainage from a motor, so whoever told you that is wrong.
what do ya think of this one it seems cheap and the same as all the others out there
http://www.tweakit.net/shop/product_info.p...roducts_id=6939
Same hi-octane extension, but DIY.
You _so_ don't want to weld an aluminium sump if you don't have experience.
If not because of the welds; then just because the driveshafts /diff run through the sump.
Get it a couple of mm wrong and it all goes to hell; repeatedly.
IMHO, even if you do have experience Leon's TIGging will blow most people out of the water anyway.
Take a look at the welds.
The baffling prevents most pickup issues; the larger capacity gives you more of a thermal sink.
Cheers,
SW
I had a stock RB26 sump lying around and filled it with water a while back. I'm happy to put 6litres of oil in the sump because:
It doesn't hit the crank,
Nearly level with the top of the sump, so oil is always at the pickup during hard acceleration etc,
It works for me.
If I had $10k I would dry sump too, but I don't.
Good luck with your ground scraping sump extension :)
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
