Hmmm Lawyer, not too sure at the moment.
the website is exactly the same design, all they have changed is the colours of the boarders, same photos and everything.
the only thing that is different is the front page. I just think it's really poor form and discredits our company. When someone makes a website wouldn't they want to make it there own design? Why would they want to copy someone else's, I don't understand.
From the whining it sounds like it's an original job but I have my doubts.
Unless you are providing some kind of paid service that involves your companys' IP you've got nothing.
who designed your company's site? was it in house or out sourced to a site designer? if it was in house, did they do the whole thing from scratch or did they use a template?
our website was outsourced.
Well then you really don't have a leg to stand on. what's not to say the same guy didn't make the other site too? pretty sure that technically speaking the site creator owns the design not your company.
Hahaha, fair point... but the guy didn't design the other one. it would be pretty funny if he did though. has this happened to anyone else though?
bound to have happened a million times over already given every man and his dog has a webpage these days.
i'd say there will be many cases of web designers pulling a sneaky one and pulling out an old template from a previous job, passing it off as new work and charging full money for doing half the work lol.
whos to say your designer didnt do that to yours in the first place? lol
  • 3 weeks later...
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
