Hmmm Lawyer, not too sure at the moment.
the website is exactly the same design, all they have changed is the colours of the boarders, same photos and everything.
the only thing that is different is the front page. I just think it's really poor form and discredits our company. When someone makes a website wouldn't they want to make it there own design? Why would they want to copy someone else's, I don't understand.
From the whining it sounds like it's an original job but I have my doubts.
Unless you are providing some kind of paid service that involves your companys' IP you've got nothing.
who designed your company's site? was it in house or out sourced to a site designer? if it was in house, did they do the whole thing from scratch or did they use a template?
our website was outsourced.
Well then you really don't have a leg to stand on. what's not to say the same guy didn't make the other site too? pretty sure that technically speaking the site creator owns the design not your company.
Hahaha, fair point... but the guy didn't design the other one. it would be pretty funny if he did though. has this happened to anyone else though?
bound to have happened a million times over already given every man and his dog has a webpage these days.
i'd say there will be many cases of web designers pulling a sneaky one and pulling out an old template from a previous job, passing it off as new work and charging full money for doing half the work lol.
whos to say your designer didnt do that to yours in the first place? lol
  • 3 weeks later...
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
