Friggin sweet shots guys :(
Sidd - I can tell right now that your logo is like that because its an image on a white background and your just copying and pasting it on and your marquee selection is getting free transformed or something?
1. Open the image with your logo on it.
2. Copy it to a new layer - MAKE SURE ITS TRANSPARENT
3. Make it however you want.
4. Save it as a PNG (there will be no background, only the logo).
5. Should be fixed!
Maikul - It works by taking a long exposure, painting the car with a light source and as long as you move fast enough you wont ghost in the photo.
  • Replies 317
Posted Images
If you were subscribed to my blog you woulda seen them already :blink:
But here ya go. I'll post more of the extreme shots later on, i was too tired and just wanted to get project 365 out of the way. But fcuk me suspension is amazing. Nearly rolled twice as well, it was awesome! I Was in the blue hilux. Had about 200kg+ in the boot full of gear plus the roof car tent.
My mate in the silver hilux, fell straight into a hole in a river crossing and almost rolled, got stuck, took us 2 hrs to get him out and cutting down of tree's and getting extremely saturated and muddy!
All this = Awesome weekend.
^ WOW CRAZY!!!!
Your friends hilux kory?
btw i have subcribed to your blog, but no email yet. I normally get it around 11am or so. Check your feedburner settings. You can change the time the email comes. Im sure you know that already.
Edited by siddr20
Yep, i set it at 11 so if i need to change things the next morning its alright hahaha. But i might make it earlier. Cheers!
Yeah my mates hilux. They are all tree-loppers so if tracks were blocked/too narrow.... Out came the chaninsaws and timmmbbeerrrrrrrrrrrrrrr!
Also with the light painting, make sure you are between the camera and the light source, or you'll pop up as a 'ghost' if you stop moving.
where's some of these 4x4 shots? ;o
Ah okay, very cool. Will have to give it a try sometime.
That's pretty clear man. that's using a tube and not a dedicated lens yeah?
I shot a couple buildings in the city over the weekend jay, I'll post one up later on :P
did you do a bunny hop to get to the 10th story? haha :D Post a pic of your bike.
24-75 f2.8 with a digital extension tube... which is kinda handy cos the camera can still do auto ISO etc. Tube knocks it down one f stop though, so can't use it with slow lenses.
http://www.digitalcamerawarehouse.com.au/prod6897.htm
still gotta use manual focus for best results.
Thanks Zennon, more to come tonight :)
Like that shot of your dog funkymonkey!
Nice night drifting shots. I like 'em!
And jay - I want a photo of your bike too! With LED light painting around it :P
oops, double post. :P
spotted this awesome looking Elgrand on the way home. It's an E51 model and not sure what rims it was wearing, but damn it looked nice. This was my attempt at a rolling shot, lol.
Day 020: 2010-11-09 by jay019, on Flickr
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
