Hi,
I'm having problems with my alarm. It doesn't register my key presses, mainly disarm. I have to press it many times before it will disarm. I've tried resetting it and reprogramming the remote. That hasn't helped. Using the valet switch to disarm it still works. Anyone on this forum in Victoria who can service these alarms? Getting very annoying when I have to stand at my car pressing the remote over and over again.
https://www.sau.com.au/forums/topic/342603-issues-with-dei-viper-791xv-alarm/
Hey. its a viper what else can I say. They are only useful as sinkers when you go fishing! Chuck it out and get e real car security product.
thats a bold comment, directed electronics make some of the best products on the market !!!! if you have the talent to wire them up right ?, failure rates are extremeley low which is why they have a lifetime warranty on most (not batteries ) parts , 99% of the time bad wiring job or remote thru a washing machine is the issue.
take it back to the place that installed it ??? they would sort it out quickly
first guess, no antenna connection or its been cut/taped on steel after someone worked on the car ,which = no range on remote, second, lost programming by fiddling around with a few things with the key on , is it a new remote??? changed the remote or car battery lately, remote battery is it in the right way?
a newer viper won't unlock if it see's mutiple alarms in close proximity being armed or disarmed. the upper models will vibrate or chirp the transmitter when that happens(anti code scanning protection)
sometimes the on off button gets mashed inside by you pushing on it too hard or crap in your pockets, if it can be unscrewed
have a look at it on the inside , the little pin behind the button , mushroomed ??? or missing ??
does it work by pushing the little rubber button with the case off? if so buy a new case or remote
if you have two remotes try the other one??
if not does it have any error code beeps or flashes ?
might be a scrambled brain if you jump started the car ? but if a DEI Authorized pro installed it ?? DEI will swap the brain no fuss most of the time
Edited by sapphiregraphics
Sounds to me that there are alot of things that could go wrong with a Vyper...Not to mention the countless emails over the past decade for the same type of problems, but don't worry Brant Alarms are still winning in the category for most unreliable car alarm.
I got someone on this forum to install it. I've tried a second remote so it's not a remote issue. I just need someone who works on alarms to have a look at it for me.
change the batteries onthe two way unit and make sure its set to user 1 on the remote. that is 90% of the issues with those. the otehr 10% has to do with antenna placement and install.
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
