hahaha If only the nissan stagea came in ute form right?
Find me one of those and I'll buy it.
will go for a test drive later this week... I owned a Ford XR6 a while ago, thought it was good for the money. does anyone know if the holden is capable of having the hook points on the outside of the tray for the soft Tornau??? Because when i owned the old Ford that was the best thing about it... i've seen the new soft tornau's and how they latch up on the inside personally i think the older ones are better.
The commodore soft cover setup is MUCH better than the clips, and Im a ford man through and through.
both the L98 and the 4L turbo are excellent engines.
the ford will carry more in the tray.
but either way I would be happy with any of them.
You mean 98 ron?
-shakehead-
Also what fails, is holden's "brand new touchscreen" system.... Soarers came out with touch screen dash in the early 1990s -.-
Go FPV
Yes they also came with an AUD equivalent $100,000+ pricetag too. Technology always filters down to the family car maker after prestige are done with it - you didn't expect Holden to make a profit off selling a $20,000 Commodore with touch screen and electric seats at the time did you?
Both these cars are great...in contrast to zebra, I'm a Holden man...but over the years I've come to appreciate both Holden and Ford for how far they have come with the vehicles they are producing. Forum opinions are useless for this kind of thing unless there are known problems with one or the other...go test drive them both and flip a coin if you get stuck. You probably won't look back with either choice.
Being the owner of a FPV and a Ford, I am a bit biased, but your choice of a BF FPV Tornado vs a new SS-V, I would get the Holden.
The reaosn is the new commo has better tech than the BF. If you put a SSV and a New FG XR6Turbo ute, I would get the Ford.
The Ford FG is so much nicer inside than the Holden and will also carry 1ton, be more responsive to mods (300rwkw under $3k) and if you get the ZF auto is a gearbox made in heaven.
good points, I'll book in for a test drive of both later this week and we'll see how I go. it's 50/50 at the moment hahaha.. I've heard great things about that ZF gearbox too, but i'm undecided whether it'll be a manual or auto, thats the next question.. cheers for the opinions though.
do u want a current model or a BF FPV????
the bf was produced up until 2008
Heres a BF FPV F6 Tornado
and here is a
Holden SS-V Redline Ute
i like holdens better but i dont mind the BA-FG shape
depends if u like V8 or Inlne 6 Turbos, just test drive and you will see
Edited by ML73ZR
and here is a
Ford looks fcking tough i reckon, the pros about the SS-V redline is that it will come with everything electronic, like GPS, reverse camera, ipod and etc...
I've got someone who would tune the ford too.. mean sucker once you get going. thanks for the input.
i like both of them. i would simply have to drive them both before i bought either. i do like the thought of the turbo 6 so i would probably lean towards that.
my sister in law's ex had a BA XR6T sedan (just the 240kw one with the 4 speed auto). got a flash tune off CAPA. before the flash (dead stock) he made 248hp (185kw). with the flash tune he made 299hp (222kw), but i can't remember whether that was at 9psi or 11psi. also that was a generic tune (basically a standard map with a slight tweak for the boost increase). the car was never put on the dyno for the tune or anything like that, so there would've been plenty more in it had he had a full tune done. even still, at 9psi it was pretty impressive. gave the feeling like it was holding back a lot too. you'd floor it and it would accelerate well (thanks to a buttload of torque), but you could tell the generic tune and low boost was holding it back and there was a heap more power there just waiting to be unleashed.
Hmmm, sounds good, what are the main differences between the FPV F6 tornado and the normal BA XR6T Ute?
F6 had better brakes, suspension, larger turbo and obviously more powerful (270kw rather than 240/245)
Also the different body kit and better interior bits.
Probably just better everything :)
Really comes down to whether you want a V8 or Turbo 6... and whether you want a brand new car vs 2nd hand.
Only thing I can think off is that if you are going to get one with auto transmission then the Ford's ZF 6 speed auto box has the advantage over the Holden's 6 speed auto box, from what I have read at least...
Only problem with driving an XR6 turbo is you have that "I just bought the fastest car on the road" stigma of the atypical XR6 turbo owner. It was much worse when these cars first came out though, very reminiscent of the great midlife WRX crisis of the 90's.
The SS's sound pretty good though, especially with an exhaust. Bang for buck mods the ford will have more power, but in the end, what are you chasing?!
hahaha, can't chase anthing, unless it's on the track... ute will handle like a bucket of shit though.. more for work purposes, plus tax saving too! :P
Easy and relatively cheap power to be had with the FPV, more so than with the holden. I'm very happy with my bf xr6t with the zf auto.
One thing though you're mentioning a 2 year old fpv and a new holden? Why not compare an FG xr6t/f6 as well?
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
