for newer cars i'd be more inclined to say that mid year is the best time to buy as you will get people selling cars to get a new one as a tax write off. round xmas time people are more concerned about buying presents, etc, so a lot of people won't bother too much about selling their car, however at the same time you might get a few people who are desperate to sell to pay for xmas presents, LOL.
hahahaha, thats what I kind of thought.
Ok lads,
So today I went out and finally bought an FPV F6!!!
I went for a newer model, 2009 FG F6 Gun metal grey! it has 17,000kms on the clock and looks unreal...
Once i take delivery i will put a few pics up, very very happy with purchase!! ARHHHH... i can't believe it.
Ok lads,
Nice work, photos please!
Surely you've already put in an order for full exhaust, some injectors and a fuel pump plus tune for a nice easy 300 rwkw+?? They're a great platform.
The problem with the GT is that until Ford put a ridiculous amount of power into the thing, or shed a ridiculous amount of weight, and properly seperate it from the rest of the product range as a true flagship...it will never be a shadow of the original GT (or HO). 12.9, is nice, but compared to the rest of the FPV and HSV offerings, nothing really special. A flagship GT that would have EVERYONE talking would IMO be capable of a low to flat 12 from the showroom.
Although not the same far reaching heritage as the gt or gtho namesake; the hsv gts is now merely a clubby r8, not a real gts as previously the gts of the lineup had a different motor and early on different boxes (4 bolt main/grp a block, aussie stroker motor, hrt blueprint stroker, callaway built ls1)
Ford releasing a factory blown gt trumps hsv trying to pass off a fake gts so they can tell customers that their current ones are cheaper than previous gen ones..
Sorry.. Its something that really irks me for some reason, and ive previously owned a commo and a hsv, never a ford
Ok lads,
Fantastic.
Pics, stat!
Sorry for the hijack.. Good choice in car dude, gun metal f6 cant go wrong
Is it auto or manual?
I Bought the Auto, test drove the manual as well... thought the Auto gearbox was way better quality, no clunking sounds..:thumbsup:
you don't really even need to change the exhaust.
so why do they say 310kw??? fly wheel
Fkc im a noob... fly wheel my fcking bad.. hahahhaah so how many at the wheels do you guys reckon 270?
Edited by macdog
very general conversion is flywheel KW = rear wheel HP. a guy i know had a stock BA xr6t (one of the 240kw ones), it made 248rwhp (185kw). with the addition of a generic flashtune (minor tune to raise the boost, but the car was never put on the dyno, the tune was just a generic tune that the place he bought the flash tune off put on there before sending it out to him) and the boost raised to 9 and 11psi it made 300hp (224kw). not sure what boost setting that was on though.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
