FOR SALE: Super AFR (Air Fuel Ratio Regulator)
As new unused, but box has been opened.
The HKS Super AFR, with its built in CPU, illuminated digital display and face mounted controls, is a simple to use fuel computer that offers many advanced features and tuning functions that were once exclusive to full engine management systems
quote from a site i read:
"*This unit is similar to the Apexi SAFC in tuning ability, but much better.
*The HKS AFR has 11 points of adjustment, the Apexi SAFC has 8
*The AFR has 6 more points of adjustment from 650~2000rpm's for idle correction, the SAFC does not have this
*The AFR has a Response Adjustment, the SAFC does not.
*The AFR's 11 adjustment points can be as close together as 50rpm's, the SAFC's 8 adjustment points are fixed & can not be changed
*The AFR has EIDS which correct the Air/Fuel signal so your car doesn't stall or go rich when your Blow Off Valve releases, the SAFC does not have this"
Website info
Click Here
Reason for selling is i will need full engine management for my plans.
BD4s price on website is $990, best price in USA ive seen is $554AU not inc shipping/taxes
So im looking for $400 (Im in Sydney)
https://www.sau.com.au/forums/topic/3427-fs-hks-airfuel-computer-safr/
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
