selling my PMU brake kit that I've been holding onto for a while, still tossing up whether or not to put it onto my track car and have some other stuff I wanna buy in the mean time. If they sell then good, if not they'll just go back to the spare parts box I'll eventually fit them to something.
This is the top of the range caliper kit from Project mu, designed for race use and extreme braking conditions. Kit has never been used, just trial fitted so the rotor hat has a few minor scratches from the wheel but nothing you would see once a wheel is on. brake lines havn't been used, still as new.
features:
  • High strength body cut from billet aluminium (not forged)
  • High performance, quality, durability and extreme braking capability
  • Aluminium alloy construction manufactured straight from billet
  • Surface finished in hard aluminite with heat-resistant coating
Caliper Specifications
  • Total length : 300.0mm
  • Total width : 160.0mm
  • Total height : 76.8mm
  • Piston Diameter : 41 / 30 / 25mm
  • Rotor Diemensions : 355mm x 32mm
Kit Includes
  • 2 x Calipers
  • 2 x Caliper Aluminium Bracket
  • 4 x TYPE HC Brake Pads
  • 2 x 355x32mm 2 Piece Rotors
  • 2 x Project Mu Teflon Brake Lines with copper washers (are for a silvia but 99% sure skylines are the same)
  • Brake Pad Springs
  • high quality allen key bolts with washers
Price is firm at $4500 pick up from Brisbane. current asking price for the same kit from Nengun is $5854 so this is a fair bargain! Low Ballers will be abused
post-57747-1288667969_thumb.jpg post-57747-1288667979_thumb.jpg post-57747-1288667991_thumb.jpg post-57747-1288668034_thumb.jpg
post-57747-1288668000_thumb.jpg post-57747-1288667959_thumb.jpg post-57747-1288668009_thumb.jpg post-57747-1288668017_thumb.jpg post-57747-1288668024_thumb.jpg post-57747-1288668052_thumb.jpg post-57747-1288668059_thumb.jpg
Edited by boost_bus180
https://www.sau.com.au/forums/topic/342733-project-mu-6-piston-brakes/
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
