R33 GTR V-SPEC Series 1 **PICS UP THIS EVENING(for now can be seen in disp pic on left) <--
-STOCK NISSAN WHITE COLOUR(clean)
-NEW 12 MONTHS REGO JUST RENEWED @ END OF OCT.
-STOCK UNWORKED MOTOR(127,000k's) WITH BOOST ONLY ADJUSTED 1-2PSI ABOVE STOCK(12PSI)
-NEW 5000K SERVICE WITH FUEL FILTER/ROYAL PURPLE OIL & OIL FILTER
-V-SPEC MODEL (STIFFER SUSPENSION STOCK + ACTIVE LSD DIFF/ NISMO DASH/BIG BREMBO BRAKES @ FRONT
-18" STARCORP IMPUL RIMS WITH 10" DEEP DISH REARS
-TANABE ADJUSTABLE COILOVERS
-3" SZIGEN CAT BACK XHAUST
-BOVS(1 HKS, 1 TYPE S)
-APEXI POD AIR FILTERS
-APEXI BOOST CONTROLLER IN CAR
-TURBO TIMER
I have driven this car daily to work n back locally for past 6 months. only had to change a afm and it is very comfortable to drive daily or just for weekend cruising! cruising easy 400km's to tank! great stock potential from these cars.
Anyone looking for a gtst skyline, spend a lil extra and enjoy all the benefits from a higher power engine, 4wd system and all the extras you get from a GTR standard!
$20000ono (cheapest vspec 33gtr on carsales!)
low k's fresh rego ready to go!
may be interested in swap plus cash depending on car.
p.m/sms or contact:0401954498
thanks, jeff.
Edited by GENETIK
https://www.sau.com.au/forums/topic/342736-r33-gtr-v-spec-s1-syd/
swap you plus 5k my way :blink:
or 10k your way and ill swap you a turbo sportivo.
pm sent!
hi res pics up on carsales site!
R33 GTR carsales ad hi res pics
  • 4 weeks later...
  • 3 weeks later...
"rb30gtr" P.M sent!
Free bump as this is still available! also not interested in swaps for other turbo cars/commo's/ute's/ only a small car plus cash!
thanks.
  • 4 weeks later...
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
