Hey guys, On another Forum I was mentioning working a 351 engine I just bought, And someone mentioned leaving it standard and Turboing it For $2000
Now I am not exactly sure you can do this.. I don't know what effect the Bigger exhaust volumes and compression are like in the 351. And for that price I don't think I could get a decent intercooler or decent pipework...
A second hand turbo, and second hand intercooler maybe...
More info would be appreciated..
Thanks..
Steve
https://www.sau.com.au/forums/topic/34276-turboing-a-v8/
Yeah, that is what I thought... Could you run a turbo of just one side... and leave the other side with extractors?
I could drop the compression with some rods or pistons... and then get a mild cam....
It is also Carby, But I can maybe tune it for a Turbo??
https://www.sau.com.au/forums/topic/34276-turboing-a-v8/#findComment-687033
Ok, it can be done for that budget but it's going to be a bit of a mission.
What model 351 is it? As for lowering the compression they run mild compression anyway (remember they had to run on shit fuel, usually around 8:1 to 9:1), do a leak down test to assess the condition of the motor.
To do this in the budget you will have to be a fairly keen fabricator or no some one.
It can be still be carby (blow through for simplicity sake) as injection blows the budget. The carby will need to be modified to accept boost, this can be done cheaply by any able carby shop. Holley, weber and dellorto off the top of my head have standard carbies that will take boost. For simplicity sake i would use a modified holley. You will need to change from a mechanical fuel pump to a electronic low pressure pump with a suited regulator.
Spark side i would recommend going electronic with mechancial advance disabled (if that model has it)
One turbo or two, can be done either way. i would go something of a decent size say a TO4E, whatever you can get used that is in good condition, maybe try a truck wreckers. Forget roller bearings and something new as it blows the budget.
Now for manifolding, what car is it in?
Usually i would mount the turbo on the passenger side and use a balance pipe from the drivers side manifold to the exhaust housing flange. To do this i woud reverse the exhaust manifolds 180 degrees. Then every tihng is facing foward. Before you go any further you need to make sure you can access the sparkplugs.
Now you need to lasercut you turbos flange and fabricate the manifolds with accosiated pipe work. Passenger side manifold with turbo flange, drivers side with cross over pipe to other side. Then you need to fabricate the pipe work to the carb, usually i would recommend that you have to carby boxed, like an airbox with the inlet letting in boost instead. This airbox (needs to be steel) needs to allow for carby backfires so you need something like an overboost valve (like the old FJ20's). Finally you need to fabricate a dump pipe and then an exhaust, now i said to mount it on the passnger side to avoid brake booster and steering box/rack so this should be fairly simple.
Then you need to run an oil return line to the sump and locate a point to get oil supply from. Water supply and return ( if needed most truck turbos are oil colled only) are a lot easier.
Now the is just how i would do it, note i haven't gone in to boost regulation, tuning etc. Blow through elimates the use of such things as BOV's and intercoolers so it is primarily a low boost set up.
I thought about doing this to another project i had in mind, and i put it into the too hard basket. It's alot of work and hassle, but it's possible
https://www.sau.com.au/forums/topic/34276-turboing-a-v8/#findComment-687139
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
