This time without breaking forum rules ( my apologies )
I am selling my r34 gtt skyline due to needing a deposit for a house.
Please see my profile for pictures.
It has rb30 bottom end with r34 neo head.
Bottem end specs - crank treated grub screwed and oil collar fitted, argo race rods, mahle skirtless pistons 40 though oversized, acl race series big ends and mains, arp head and main studs, rb25 oil pump, repositioned second timing belt tensioner. cometic mls head gasket.
Head full service and tomei type b cams, vvti retained.
bolt ons - plazmaman plenum and plazmaman throttle body, extreme turbo manifolds 100 series exhauste manifold double black ceramic coated, tial 44mm wastegate, garrett to4z turbo rear housing ceramic coated, sard rising rate fuel reg, sard 800cc injectors, 2 bosch 044 fuel pumps feeding twin entry fuel rail, custom surge tank, oil cooler kit with thermostate block. large front mount intercooler, turbosmart blowoff valve, npc race clutch, greddy profec b spec 2 boost controller, custom alloy airbox with large k&n air filter.
Engine bay got resprayed when engine was out getting built. car has lenzo s7 wheels 19 inch with good tread on tyres, also has nismo adjustable rear wing stays.
Has adjustable camber and castor arms and fitted with dba 4000 front rotors
This car goes extremely well, huge power and responce with a lot of rb30 torque. all is managed by an autronic sm4 computer system.
ANY REALISTIC OFFER CONSIDERED FOR QUICK SALE
my asking price is very low as i really need to sell this car but also reflects the minor faults i have found with the car and these are, a few minor scratches on the vehicle, the clear coat has a couple of small patches that have lifted on the rear wing ( just needs re-clearing ) there are wear marks in the carpet on the drivers side from my foot rubbing through when i didnt have floor mats fitted. the low price reflects these faults and are all easily fixed. car made over 350rwkw last time on the dyno but stopped tuning there only due to the engine still running in it has now done 4500km since built and is ready to be opened right up will easily make over 400kw with the current setup.
car is located in perth but will happily put it on a car transporter wich winning bidder would organise. has current nsw rego untill june 2011 but will also transfer it to WA for a local buyer.
asking $15000
please p.m any enquiries
https://www.sau.com.au/forums/topic/342765-r34-gtt/
Sounds like a good thing at a realistic price, I would PM you but as im new here i dont have enough posts up to qualify me. I'm assuming that as the car has NSW rego you have payed transport costs to WA and was hoping you could advise on these costs, as i would have to transport it back to NSW and need to consider these costs.
Cheers
Richie
https://www.sau.com.au/forums/topic/342765-r34-gtt/#findComment-5528420
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
