Hi guys, does anyone have some numbers from yesterday's meeting? I know GTR-700 ran a 8.44(?) on E/T slicks, were there any other Skyline or notable times?
What was your general impression of the event? After getting there at 2:30pm I only had a few hours before I had to leave. Was pretty p'd off that they had a 2 hour break from 3-5pm...
https://www.sau.com.au/forums/topic/34277-wsid-drag-combat-results/
2rismo went from a 13.471 -> 13.041sec with the help of some naws :wassup:
The event as a whole I thought was extremely disappointing and certainly not worth $30 considering that the week before (Summer Nationals) I paid an extra $5 and seen an -entire- day of real professional drag cars.
I won't be going back for the 4th and final round thats for sure, i'll stick to the Wed nite street meets for half the price for my drag racing entertainment.
Benny and I caught up at the end of the night and had a bit of a bitch/review of the situation.
With the $30 entry fee they gave you a free magazine, which was a good idea as the were massive delays and the magazine was read cover to cover. I got there at about 5 and there was not a single run to at least 6.15. As ben said the street meets were run alot better.
But bear in mind fellas that this was there first shot at it at the new strip and in sydney so like the shows they will hopefully get better. I remember going to the first Autosalon (showing my age) at the horden pav and it was shit but now look at the series, its international. Even though the cars aren't always my cup of tea the shows are entertaining.
oh yeah 2rismo i caught a couple of your runs, very impressive mate.
Thanks for the comments guys... The event definitely could of been run a lot better...
YRL05S, if you got there late you wouldve seen the 13.0 and 13.1. Will be much better in the near with tyres that arent as hard as rocks!#@$#@$!#$
115mph should be more like 12.0 - 12.5 not 13.0 !!!
Adrian
"DRAGTS" - Dude, I would seriously consider getting the Power FC tuned before anything else. But cheap tyres? I am ALWAYS Listening when someone says that.
I want BF Comp TA's!!!!! NOW NOW NOW!!!
Adrian
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
