new pretty gate is in and new screamer made up. booked in for the tune this friday.
routed the vac line so it goes through the heatsheild and mounted my boost solenoid (ecu has boost control in it). should help with the vac line from perishing from heat.
  • Like 1
Car is still boosting high for some reason, but now makes 351kw @20psi. If I drop it back to 18psi it sat at 345kw. But it is really happy making that power atm.
Also dropped the rev's back to 6500, and the afr's are 11 to 1 for a bit of safety
Dont mind the dip from 4700 to 6000, got a manifold leak on the last three runs from Not tight enough and cooling down over lunch.
Well that didnt go as well as I hoped.
Rocked up to a speed off the streets day at wakie yesterday for a bit of a test day, got 8 laps in and broke a stub axle sad.gif
Other than that the car felt excellent. The extra power and reduced weight has really change the car. Going to take a few proper laps to get used to, but the car will take any opportunity to slap me in the face if I don’t concentrate
I did manage a 1.10.10 in the lap before the axle went, which is about 1 second quicker than what i normally do in the 1st session. So i take that as a good indication im on the right track (no pun intended tongue.gif )
Also, even though tyre were cold, grip feels better too. Definitely more front and rear, was less understeery with the modified splitter. Will have to wait until I get a proper run to judge the rear.
Timmies best raceface
bettter look at the front bar, still need to do the skirts
Im now trying to find a couple of sets of 4 stud stub axles, so if you have a spare that you want to set cheaply please PM me.
As much as i would like to, im not going to order the billet ones from the states as they will take too long to get made and sent.
ive got two sets lined up already, hopefully i'll be able to get a set in this weekend.
Only thing that worries me is why it broke.
was it because of the extra power and grip (even though not much) or was it just because it was 27 years old and stressed from the last couple of years of track work, or a combination of the two?
either way i dont see much point of pouring much more money into the rear end as it is, and so after wtac i will be putting my stag rear end in.
if you've got doubts about it, just don't do any launches and take gear changes a bit easier (ie don't power shift). Most driveline shock happens when you suddenly put power through it rather than just accelerating in gear.
easy, turn up and hand them some cash. :)
everything with 4 wheels are allowed. from street cars to race to open wheelers and karts.
thought about taking the rover out for a spin but im sure it would fall over first corner...
well, i was going to try and get back to wakie today, but i forgot imy sisters uni graduation was on.
so im going to go next week.
In other news, repacement stub axles are in and i now also have a spare set. thanks james smiley.gif
These turned up too 255/40r17s soft compound (actually 265s). I'd like to thank everyone for their help it has really made a big difference to getting to wtac and my stress levels smiley.gif
lowered the skirts to match the front. Not the prettiest but should help stop some air getting sucked under the car. (front bar/splitter just sitting there atm)
Once again, please excuse the mess.
got some new stickers ready to go on too.
  • Like 1
Had a good day at the track today smiley.gif shake down and test one set of the advans
New PB 1:06.31, beating my old pb by 1.1sec yeah baby!
Both the car and I felt really good, and the grip from the advans is just insane.
Got a bit of a boost leak too
Easto was there too, but suffered a engine eating itself.
unedited clip, so skip too 3min for the start or 7:50 for the hop lap.
http://www.youtube.com/watch?feature=player_embedded&v=rDtp493ad4s
probably 85% tyres, rest was tune, aero, and weight reduction..
has more in it too, i think a 1.05 may be on the cards next time im there. didnt want to push too hard with wtac just around the corner!
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
