marc when you're done spewing your paragraph upon paragraph of close minded opinions...
it was an RB20DE+T setup.
high compression motor. still free revving. still higher torque than DET..
so it still had the torque and only had a small conservative setup for high response and not-much lag...
boost came in at about 2500rpm.. but it still had the torque of the DE head...
it was actually a very fast motor. i would never go standard 20 det. that engine was different.
to summarize. you're dumb.
anyway.. back OT. so. gonna get a lexus GS?
rb20DE are still a pathetic motor. even with a turbo bolted on.
I think the worlds quickest drag Skyline is marginally quicker than the best Supra.
skyline may be a pubic hair faster than the supra (0.02 of a second or something like that), but engine wise there are faster 2jz's than rb's. fastest rb powered car i think is in the low 7's. fastest 2jz powered car is mid 6's.
  • Replies 52
Sure it's a bigger displacement, but what has the better racing pedigree?
The difference to cars like newish corollas/mazda3s etc is that they feel like the throttle positions are more biassed towards light throttle. I reckon 1/3 throttle in a corolla is really opening the throttle body at 50+%. Cause you barely breathe on the thing and it takes off, but push the pedal further down and bugger all happens.
that more comes down to which car has a better racing pedigree? it would be the GTR because it has the advantage of 4wd. engine wise the 2jz is a better engine in it's stock form. it will handle more power in it's stock form thanks to having forged internals.
+1
With my dad's Corolla 10% throttle is like 50% throttle, so it gives you this false "illusion" that the car has some grunt... mash the paddle all the way to floor & sh*t all happens...
like the time I was on my way to kalgoorlie & was overtaking some 3 trailer semis going about 90km/h, change lanes, floor it 100%, car downshifts to 2nd, eng rev jumps to 5500rpm & makes a horrible buzzing sound, look at my speedo I haven't even gone over 100km/h yet...
+1
it's an auto corolla, what do you expect? lol
they do NOT have forged internals. I have seen a busted 2j piston and they are cast for sure. They will make 450rwkw before you start to get uncomfortable where as a 26 will be around 400rwkw before you start thinking rebuild. The 2j will likely last longer, after spending some time with the supra club up here we have learned that failures are every bit as common for them as they are for the people in our club. The 2j is more power productive and durable but it isnt by as much as people think.
  • 2 months later...
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
