Want New Rims Sale-straight Pipes,wheels,spacers,nardi,cusco
Random shit for sale
work vxss,bit of rash,nothing major,no buckles with wanli and random tires
black centres,chrome lip
17x8 +36 rears 225/45
17x7 +32 front 215/45
4x114.3 pcd
can include 2pairs of 25mm spacers if you pay my asking price
$500
AM Performance straight pipes,3 inch inlet,twin 3 inch out in stainless
look sex,super high quality
$180
cusco c-spanner
$50
nardi Torino wheel,slightly bent spoke,easy fixwith horn button
$40
r33gtr a pillar twin gauge mount,can include an a pillar to go with it with holes already drilled for wiring so you don't f**k up your original
$100
r34 lowered springs,bright blue,can't remember wat brand.selling for a dude I know
$100 for all 4
hks turbo timer
$30 with loom
autometer shift light
$50 with loom
Mostly negotiable,but not friendly to lowballers
can't upload pics off iPhone,so SMS me on 0421754575 or pm your number and I'll send you a pic of any item
peace out
  • 3 weeks later...
 Share
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
    • Oh for sure, I'm just recounting my thoughts 😎 I'm not what you've got there to fuzt with.... likely my first idea was on the money -- rebuild or replace connectors. You can get a lot of connector stuff here  -> https://www.rapidcables.com.au/ Didn't look in the boot of mine, because I replaced these when I renewed the pump (plastic of connectors had gone brittle) edit: what I used... https://www.efihardware.com/products/2120/Deutsch-DTM-Connector-Kit-6-Pin ...cheaper... https://www.ebay.com.au/itm/364900039138
    • In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
