ok i have an RB20DET in my ride as we speak
was thinking about running some mods on it
or upgrading to an RB25DET or RB25DET-NEO what you think
whats the pros and cons with the RB20DET, RB25DET & the RBB25DET-neo
currently my rb20 is running
*Stock rb20 motor
*300zx 45v3 t3 turbo
*10-12 psi boost
*TurboXS boost controller
*Blitz bov
*Blitz LM 3" intercooler
*2.5 intercooler piping
*3" free flow stainless exaust
*Custom RB26 side mount intake manifold
*Upgraded ecu ( flashed\remapped )
*Fidanza 4.3 ceramic clutch kit
*NGK iridium spark plugs #7
*Walbro external fuel pump
Was going to upgrade to......
*Rebuild with Genuine Nissan complete engine kit
*Genuine nissan piston rings
*Garrett GT3076r or hks GT3037pro-s
*Xo2 exhaust manifold
*Sard fuel press reg
*550cc injectors
*AEM water/meth injection kit
*Greedy E-manage ultimate or haltech unit (TRY TUNE TO ABOUT 18-20PSI)
*Map sensor setup
*Wide band o2
*Cometic metal head gasket
*ACL race bearings
*ARP head bolts
*HKS timing belt
*Oil cooler
*Oil rerun lines from head to block
  • Like 1
https://www.sau.com.au/forums/topic/342842-rb20det-vs-rb25det/
Really depends what your goals are. How partial are you to your RB20?
Usually in these circumstances it's easier to drop an rb25 in. By keeping the Rb20 you'll always be behind the '8 ball', given that the extra 500cc is a 25% increase over the stock rb20.
Depending on your power goals, I'd personally take a rb25 if you can do it cheap enough.
Edit: was also going to say I hate mods going to waste. But a lot of yours could be applicable to an rb25 set-up. Now is as good a time as any to make this decision. Before you spend money for specific rb20 components
Edited by Truffles
Factory RB25 you can do 280rwkw safely (about the limit IMO).
A RB20 @ this power level will be quite laggy, however the RB25 isn't "too" bad. Its basically where the compromise point is.
But as asked, depends what you want mate.
Use of car? Motorsport? Response required? Drag? what? :verymad:
As stated, it really does depend on your goals. There is a thread I think all RB20 owners should read before giving up on the motor.
http://www.skylinesaustralia.com/forums/Bo...20-t330619.html
Personally Im not an RB25 fan boy. I think the lag limitations of the RB20 keep it grounded as far as usable and reliable power goes. I personally am a fan of Roy's results, and I think a 260rwkw RB20 with delivery like his would be an excellent motor.
Maybe consider going down the TD06 route before you give up on your RB20, at the end of the day you can transfer your turbo kit over to your new motor should you decide to go RB25 later.
More TD06 info here:
http://www.skylinesaustralia.com/forums/Le...tml&hl=td06
get a 25 you will never look back, it is sooo different to drive, more low down power, can make more power before getting laggy and even then you still have more off boost capacity so it isn't as bad.
VCT is a godsend and makes it so much nicer to drive as well, I would never ever get an rb20 again, they sound amazing but that is it, I think I'd go an SR20 before an RB20.
Ive had 2 rb20s and 1 rb25 with a highflow turbo and the difference is night and day.
If you have an R32 you can reuse half the stuff anyway, intake etc, use the rb20 ecu and get a nistune module, eboost street so you can retain the VCT and you can use all the old sensors, means you don't need a half cut, just the raw motor, might need to change a few things like throttle body but that is it.
Edited by Rolls
yeh i dunno about this personally i think rb20's are highly underrated and very usable up to the 250kw range, i'd never remove a running one for a 25.
when my last rb20 blew a headgasket i went engine hunting, i already had a rb25 box in the car so i got a rb25 engine cheap and dropped that in.
now both of these engines were running stock turbos with 1 bar of boost the rb20 would be around 160kw and the 25 was making 193kw.
the 25 was a decent upgrade but if i had a 25 turbo on the 20 i dont think the gap would of been all that great.....
i also think its crazy to rebuild a perfectly good running engine but if your deadset on doing a rebuild i'd be looking at a 25/30 build for the 3L's of fury!
peak power may be similar but the 25 will be much quicker on the street.
imo, get yourself a 32 25de head, bolt it to a 30e block and throw on a gt30. can re use all your silvertop loom etc that way and nistune the ecu
below 200kw the difference isn't that much, but when you get closer to 250kw the difference is massive, drive both and you will see what I mean, an rb25 making 250kw has more punch down low than a stock rb20, it really is night and day.
300rwkw on an rb25det won't last very long...
many cars on here say otherwise...
i've been running ~300rwkw for almost 2 years now on stock internals as have a heap of others
Unfortunately the OP is in Trinidad/Tobago and they don't have RB30E's over there.. I've been telling him to build a 30 for ages ;)
whats your reasoning for this? i beg to differ. in fact if u ignore the pistons for the most part, 25 and 30 internals also a farely strong. u may drop a bearing at 300kw but thats due to the fact they are old and f**ked anyway.
and to be honest i havnt seen too many problems with the 25 pistons its usually the australian 30et pistons. (stock vl turb pistons had a tendancy to 'melt' lol)
not having a dig just curious. you may have seen some fail and i just havnt come across it yet.
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
