Hey guys,
just a little run down of my set up...
i have a rb30 twin cam in the build running a Gt35/40 1.06, looking at close to 400rwkw at the wheels once completed.
now the machine shop has asked me to give him the flywheel & pressure plate off the clutch im going to use to balance everything together...
& i dont have a clutch yet.
Now the box ill be running is a R33 Gtst skyline 5 speed -i may run a helical dog box from PPG once i blow this standard box.
will i need a Triple plate clutch or can i get away with a twin ??
what you guys thinkk?
Thanks.
https://www.sau.com.au/forums/topic/342847-need-help-with-deciding-clutch/
Both our track cars make 550hp at the wheels. One a 33GTR and the other a 33GTST. Both use an NPC Bigmouth Track Single plate clutch. Various track and drag days have been done on them without issues. I have pulled both clutches out after events and they still look brand new.
We have tested them to 610hp at the wheels but anything over that and you're on your own.
You MUST run a billet flywheel!
Thanks for the replies..
after doing some more homework i have noticed a few people using Jim Berry clutches such as the "full monty" setup.
i actually rang Jim up and explained to him what i need, he has suggest the full monty set up with 4000lb clamp pressure plate... sounds good..
the car will see a far few open track days...
whats peoples thoughts on Jim Berry, i have heard mostly good things about him...
Hang on Im about to pay for and pick up my twincam rb30. Full forged engine. Modified head. Hope to make 400 kw also but my engine builder told me from the start my standard flywheel would be fine??? Is this not the case? Crank has already been balanced with my standard flywheel and my balancer. ?
Im going to use a standard RB30 flywheel.. thats what most have recommended..
<cut>
Is it drivable on the street? Or are these track-only cars?
Just brought a Jim Berry Full Monty Clutch kit... cost me $1347.50 delivered to sydney.
Jim is a top bloke, great to deal with!
That's almost double what you'd pay for the same clutch from NPC
If you value your feet and your car then yes.
May not explode like a grenade but the more over 300rwkw you are the higher the chance of it happening
I hope AT LEAST you have the turbo 25 flywheel and not using the RB30 flywheel?
Both are street cars
yeah I would think twice about using a heavy duty clutch on a big power car with a stock RB30 flywheel. do a search for jim berry clutches on this forum and check out the number of people who have had flywheel/clutch explosions using them. including one poor bloke whose car was so badly damaged it was written off with firewall and chassis rail damage (even guard and bonnet damage and engine block damage) which his jim berry clutch exploded at the start line on the drag strip with about 350kw. it's up to you buy on cars with that much power I would think a new performance flywheel would be a no brainer.
exactly the reason why i skipped a rebuilt jb clutch and when nismo twin, didnt want to take a chance
had one of jims heavy duty singles 4200pounds clamp explode coming off the clutch a bit fast wilst rolling in second..with only 400rwhp, I'd go a multiplate and avoid the high clamp singles.
after look at the OS giken triple I'm currently running with 650+rwhp they are quality, just streetable, I'm sure the their twins with sprung centre would be very streetable
  • 1 month later...
No the best clutches ever bar none are carbon triples. Massive hp handling and drives 90% like stock. They are very progressive. I really dont understand why people even bother with singles on modified cars ? Once you try an xtreme / ATS / Carbonetics (all the same) triple you will never use anything else. More progressive tha a xtreme cushioned 9 button ceramic single and handles 1400hp with 6.5kg flywheel. They really do shit on all other clutches out there.
Edited by BK
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
