1993 Skyline GTS-t (track only)
104,000 kms
Black (resprayed from wine red)
2JZ-GTE 3.0 litre 6 cylinder turbo
5 speed manual transmission (R154 box, ex-JZX100)
Master Power turbo (approx T70 size from what I can gather – 0.70/0.60 ARs)
External wastegate
Twin plate clutch
Aftermarket FMIC
Aftermarket exhaust
Series 2 front end and bodykit
4 door headlights
GTR rear wing
GTR instrument cluster
Adjustable coilovers
Aftermarket defi style gauges
Tacho with shift light
Momo steering wheel
Factory electric sunroof
Aftermarket 18” alloy wheels with good sizes and offset.
Apexi SAFC
Turbo Timer
Toyota hydrofan and radiator with low/high speed controller
POD filter
TSL installed an SAFC and gave it a quick tune. On 9psi it made 235rwkws. The limiter (or fuel cut?) was never removed so only revs to around 5000 - 5500 rpm
It still has the factory VLSD but its shimmed tight.
The 2J conversion it was all done in Japland and it drives like it was meant to be there. I havent had the running gear out but from what I can see the conversion is extremely good. Engine runs smooth as silk and the gearbox and clutch is perfect. The exhaust it a bitsa tho so could probably do with a custom 3" catback and the pass window doesnt work so I guess the reg need replacing.
10K FIRM
  • 1 month later...
track car only or is it currently registered ?
considering the first line of the add says "track only" id say its not registered
  • 5 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
104,000 kms
External wastegate
Twin plate clutch
Aftermarket FMIC
Aftermarket exhaust
4 door headlights
GTR rear wing
Momo steering wheel
Apexi SAFC
Turbo Timer
POD filter
10K FIRM
BUMP
