hi all. im totally new in skyline sense.
coz the weather recently , i found my car is really slippery in wet. although in 3 gear around 3000rpm, it still can go side way on a straight line accelerating.
is it normal?
i ve checked my tyre, still in good condition. i was just worrying is it because any inappropriate setting
R33 GTST SeriesII
190kw at 12psi
Falken tyre: F235 R255
thx :verymad:
https://www.sau.com.au/forums/topic/342861-really-slippery-in-wet/
  • Replies 44
learn throttle control in the wet lol, I can drive with the shitest tyres that were 100 a side and with 270kw I can make it not slide in the wet just control your foot.
this, best answer you'll get
ps. u were @ oct winton drift?
Moved here...
Before this totally goes off the rails, which inevitable...
I can spin the tyres in a KE Ford Laser...
It would be lucky to have what, 40fwkw? Used to be able to have it wheel spinning into 3rd which whilst amusing, was rather pointless.
So have a think about that. Totally comes down to throttle control. If you expect a 190rwkw car to have traction in the wet, then you are very naive good sir.
Any car will spin the wheels in the wet if you force it.
Failing that, I would suggest using 99% throttle instead of 100%. That'll fix it.
yeh 33 no front bar was me :P
lol nismoid my mate had one of those lasers we got a great run on chapel one night raining lined up the tram lines epic lols all the way to d'nong road from just after jam factory.. should note was a loooooooooooooooooong time ago.
but there is nothing like the lols you get out of shitb0x cars.
Come on !! You're kidding me. There are so many possibilities for a joke here I just don't know where to start. So I'll try to be serious and just say that perhaps a you should sit on your lounge at home and take your shoes off. See that thing at the end of your leg ? That's a foot. Now, see the little sausage type thingy jiggys coming off your foot ? They're toes. OK, try if you can to wiggle your toes. Good, good. Do that every night for a week and when you have full control of the nerves from your brain to your toes just take a full day off and rest.
Ok, here we go, the big day. I want you to see if you can control the movement of your right foot. Woe, woe, easy now, it may be a little out of control at first since you have never tied to control it before. Try some small rotations at first then after a month or so build up to some up down movements. I find hanging your tongue out of your mouth may help stabilise the whole area though drooling can be a problem. Give this maybe twelve months and only then will the nerves between your brain and foot be fully functional. You may now grab the keys to your new Hyundai Getz and try to drive like a member of the human race. :P
the thing that concerns me most is your toes look like sausages :(
A Mate & I both had one each, brought em @ the same time as well...
A manual one was simply the most amusing, one of the funniest cars i have owned - I remember going down the GOR in it, doing 60-80km/h around some of the corners was hilarious with the body roll and tyre squeal. It almost made the GOR 100x better considering you can never open a fast skyline up safely these days in those parts haha.
yerrhh gotta be manual scary to think they were cutting edge at some point in history i miss having crap cars that you can slam into gutters not bother locking not bother servicing an that..
serious cars are too serious
Lasers are a lot of things.....cutting edge isn't f**kin one of them!!
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
