Hi all,
I finally managed to get my dream.
Bought it off the first owner in Oz, he had it for 2 years. It has 101,000 KM's on it, has had its 100,000km service, timing belt done etc.
Unmodified except pod's and turbo timer.
Wheels are next on the agenda!! After the bank account recovers though. LOL
Took these pic's with my mobile, will take some better ones with a camera and post them.
https://www.sau.com.au/forums/topic/342885-finally/
Congratulations Eric, as it looks in great nick.
Slept in it yet? :) More foot room in the rear than the other GT-Rs!
God_speed has one with about the same no. of Kms > about to sell his soon > 100kKm service done too.
https://www.sau.com.au/forums/topic/342885-finally/#findComment-5530935
Thanks Terry, good to see a fellow Foz owner too! :rofl2:
No, haven't slept in it yet but was pretty close to on the night I got it. Hahaha!!
https://www.sau.com.au/forums/topic/342885-finally/#findComment-5531534
Looks good mate enjoy your ride! I've loved mine ever since I've owned it. take it on some nice twisty roads you'll appreciate it even more. Cheers.
Thanks Nathan.
Yeah, I have only had it for a couple of days and love it already. Already took it on a decent run, feels very different through the corners, smooth. My Foz isn't too bad at cornering either! :)
https://www.sau.com.au/forums/topic/342885-finally/#findComment-5531539
congrats on the purchase man, very nice and very clean looking r33. Imo, go the TE's in bronze :D . Btw, you might wanna fix your profile coz you wrote R34 GT-R in the cars owned section after (dream). Unless you mean you now own a R33 as well as a R34 which in that case just makes me incredibly jealous lol
https://www.sau.com.au/forums/topic/342885-finally/#findComment-5532487
Maybe it's better to pay more and get TE37 !! :(
someone posting pictures they know nothing about.
If you saw what the EVO did in the before that - you'd hardly be surprised the rim ended out like that.
Several users here have run them FINE on the circuit for quite some time now without any issue at all.
https://www.sau.com.au/forums/topic/342885-finally/#findComment-5537435
Thanks all.
Really love this car now....I'm hooked! Hahaha.
motor is making a slight tapping noise, but from what I read on these forums the RB26DETT has a slight tapping noise. Freaked me out at first, then read the info on here and it calmed me down.
https://www.sau.com.au/forums/topic/342885-finally/#findComment-5547206
    • Good to hear. Hopefully you're happy enough not to notice when driving and just enjoy yourself.
    • I mean, most of us just love cars. Doesnt necessarily have to be a skyline.
    • Did you pick up a manual cluster to remove the position indicator?  (Pretty sure the 34 has the gear position in the cluster, but it's been a while)
    • Here is a recipe. Sonic blocks till you get one that has a good enough bore. Get a torque plate and block brace, use your choice of fasteners (arp ect) bolt the thing together empty, half fill it and let it cure. Release it when it has, go to a REPUTABLE RB Builder and get the thing line bored/honed and cylinder honed to size, then wash. Once its all clean and dandy, wash and blow it out again. Then again.  Assemble said engine to your desired clearances with oil control mods, gasket to suit desired CR/Squish ect. Attach your extended sump with proper trap door oil baffles and head drain plumbed to sump with a SUMP BREATHER SYSTEM. Build your front diff with a decent LSD, rebuild your transfer case with a few extra plates, more than likely replace your tailshaft centre bearing and tighten up the rear diff. Tune to minimise excessive midrange cylinder pressure (timing unless you like to split bores and rebuild engines) Enjoy your engine, but hate the fact you are now destroying engine mounts, gearboxes, gearbox mounts, diff output flanges and driveshafts, diff mounts, tailshafts and front CV's.   Disclaimer.... Ive never done any of the aforementioned stuff.......
    • 440s will support well over 400HP on petrol, which is a decent place to be for an RB20. 230+rwkW. Will be a safer bet for idle/low load. 550s would be nice for the extra headroom. I've made the same decision with mine (Neo25). 1000s are probably too big for the Nistuned ECU, so I have some smaller ones.
