Hi guys and gurlz
Time to let one of my cars Go.
its an R32 4 Door Gtst, Jap pumped rear guards, Imported By Garage Hiramatsu.
im happy to sell it as a whole car or part it out.
It has Brembo's but ill be keeping them.
its has an RB25DET with Power FC and GT30 making around 385rwhp
RB25DET Gearbox (second gear Grinds when going in to gear)
Nismo 2 Way LSD.
everything Adjustable underneath,
is the Sunroof Model.
Almost Full interior.
PM Me with Any Offers Regarding Parts or offers for the Whole Car
Some Parts will not be available as ill be putting them on my Other Skyline.
GTR Guards for sale,
GTR Bar/Grille Not for sale
Side Skirts Not For Sale
Call or sms Brad 0450 194 170 or pm me
Located on the Gold Coast
Uploaded with ImageShack.us
https://www.sau.com.au/forums/topic/342909-nissan-r32-4-door-skyline-gtst-rb25/
Here's a free bump for you.
But...Rooted gearbox, no wheels, crappy brakes, no rear bumper, no bonnet, smashed and different colour panels, no hope of rego.
Seriously part it out mate, if you have enough good parts left you'll get $7000 but no one will give you that sort of money for the whole car.
actually it does come with a Rear Bar, and i have sold my other skyline so it will now come with the brembos, wheels and has a GTR Bonnet.
But if anyone wants parts hit me up, as it says im willing to part it out but all needs to be gone by the weekend
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
