  • Replies 109
Posted Images
was there at 5... im there at 5 most days.. just drop me a txt tommorow b4 5 tommorow if im in the city i will call you and meet to give coin
Sorry mate, I start at 6am, so long gone by 5pm :) The other option is to drop into an ANZ Branch, I think they close at 4:30pm.
i think i will go to the anz, i dont leave work till 4.30 n then it takes a half hour to get into the city
No worries, just go the the ANZ with the account details on the first post, and they'll transfer the money :P
Tested out the R34 around Nurburgring over the weekend. Everything is looking good at our end.
The car handles really well. I've set the Easy setting the same as Medium so that everyone runs at a similar setting.
We wouldn't want someone to pick easy and leave everyone for dead.
You'll have the ability to turn the traction control to off/low/medium/high while driving.
There are 4 view settings -
Default view - Inside the car looking out the dash
Bonnet view - looking over the bonnet
Front view - Viewing from the front with none of your car in site
Tail cam (hard to drive as the motion doesn't compliment the visual movement of the car doesn't work well together
Easy/Medium - Medium steering and braking help - High traction control - Auto resumes in 8 secs after leaving the gear shifter alone
Hard - No steering or braking help - medium traction - Auto resumes in 30 secs after leaving the gear shifter alone
The cars have a clutch but the software is set on autoclutch to prevent everyone from stalling when they crash. You can drop the clutch anytime and it will work as a normal clutch would.
If you select Easy/Medium the cars will start in auto, when you touch the sequential shifter it will change to manual. If you leave the gears alone for 8 secs it will revert back to auto
If you select Hard you will need to put the car in gear at the start - it will then run in auto.
If you touch the gears it will change to manual and stay in manual. If you leave the shifter alone for longer than 30sec it will revert back to auto again.
So there you go.
Tom Kennedy
SimWorld Entertainment
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
