hey guys.... i have heaps of gauges in the boxes.. NEW... that i want to get rid of super cheap
i have :
DRIFT crystal series....
-air fuel ratio 52mm
-oil temp 52mm
-5" boost gauge
-boost 52mm
-vacuum 52mm
-volt 52mm
-water temp 52mm
also have ignite series 2....
-air/fuel ratio 52mm
-oil pressure 52mm
-oil temp 52mm
-vacuum 52mm
please let me know what you want and i will give you a price.... but as a rough idea.... 52mm will be about $50 each approx!
thats pretty dammn cheap! :)
https://www.sau.com.au/forums/topic/342989-gauges-all-sorts-new-in-boxes-cheap/
some pics and prices would help...
tell me what gauges your after and ill let you know how much ... and as for pics .. i can email them to you if you would like
oh and by the way everyone.... i have a wrx '01 - '03 cat back stainless drift exhaust for sale too ... $500 mint condition
Edited by roney1gtr
do they come with everything needed or just gauges alone?
i need
-boost 52mm
-water temp 52mm
-oil pressure 52mm
-oil temp 52mm
[email protected]
thanks
the gauges are in the boxes with everything you need !!! ill send you pics and prices
5 of each? Sounds like a trader ad.
Please consult the thread below if you wish to look into becoming a registered trader:
http://www.skylinesaustralia.com/forums/Bu...se-t294953.html
Closed.
Guest
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
