hey guys just chucking my soarer up for sale as i miss manual and want to start drifting so need this gone.
will consider swaps for some kind of import + cash my way/your way depending on what you offering . but am really after cash .
ok so its a 1991 imported uzz31 (1uz v8 ) toyota soarer , rebadged as lexus . 172xxx kms.
-brand new aftermaket black headlights ( has halo ring and Leds for park lights )
-4 speed auto
-wood grain interior
-all leather and everything electic
-kenwood ipod headunit ( sold it )
-sticker lip :D ( can easily be pulled off if not your taste )
-buddy club look alike 17' rims
-resprayed gloss black with metal flake
-air bags taken out and now replaced stock coilovers with uncut lowered king
springs in ( still have the air bags here )
-twin cannons
-tinted windows
-6 months rego getting put on soon
-rolled guards
-alarm and imobiliser
bad sides are .
drivers side door handle cable has stretched and can only be opened from the outside
and passenger window goes down but doesnt go back up :dunno:
but apart from that the car is wonderful to drive nice and cruisy and havnt had any problems apart from above.
asking $6500 need it gone got my next car lined up :) feel free to offer swaps .
located in hobart , pm or txt me if interested :laugh: 0428822856
[url="
Edited by SeanyBoy
https://www.sau.com.au/forums/topic/343031-fstoyota-soarer/
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
