I have for sale a ZEX Nitrous Show Purge Kit, originally I bought this for car shows to have installed to vent out of my front guards, however as I didnt have time to fit it before Autosalon and I'm going to Tokyo in 11 days I need this gone ASAP.
Package Includes:
10lb Nitrous Bottle
Clamps - Bottle Holder
Braided Line
2 x Green LEDs to illuminate the purge cloud which is 15ft
Dual outlet to allow dual PURGE rather than single purge that comes standard with the Kit.
In total it cost me $550 to have it imported from USA, but as I have no use for it any reasonable offers will be considered. Looking for around $300 mark
This is what the kit looks like if you want extra details also has a VIDEO.
http://www.zex.com/Products/PurgeKits.asp
https://www.sau.com.au/forums/topic/343094-car-show-nitrous-purge-kit/
Yeh it'll fit on any car being a purge kit...never fitted to my car so I dont know how long it takes.
But the guys at my workshop who were going to do install said it takes about hour to hour and a half...
  • 3 weeks later...
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
