yeah thats why you go tomei, they dont slap
it has nothing to do with the brand it has everything to do with the fact they are forged and the clearances you use.
You can minimise slapping by running as tight clearances as possible but the only way to avoid it entirely is to use non forged pistons, so no they will still slap.
And pretty sure Tomei pistons are made by Cosworth...I know some of them were.
If you dont want piston slap run a long skirt piston and really tight clearances. might cost you a handful of horsepower but much better for a street engine.
its everything to do with the brand, tomei use different forging process's and different blends of metals for there pistons, thats why you can set the piston to bore distance closer (as specified by tomei), and there not made by cosworth, ALOT of people that have visited the tomei workshop can back this up!
Surely their expansion properties are not that much different? Does anyone have them, I'm curious.
I'm sure they vary a bit but surely you'll still need a larger clearance than stock pistons.
i have some on the way, there were a few threads on gtr uk about them too, people where questioning about the piston to bore clearance, and found out it was due to how much the expand when heated, which is very minimal. There also the only piston manufacturer with cooling chanels just like the OEM rb26 and 2jz pistons
Interesting, perhaps the cooling channels restrict the expansion.
thats a good point, i know you can get non cooling too, and even the non cooling pistons have no slap.....
http://www.tomei-p.co.jp/_2003web-catalogu...iston_rset.html
some silent reading for you :P
no doubt they are a good piston. but most motors, built tight... won't have a problem regardless of what brand.
motors with wiseco, cp, whatever. ive heard plenty and all of them you couldn't pick if you tried.
plenty of tried and proven pistons out there without having to blow $3000 on tomei cooling channel items when a decent set will set you back around 1200.
either way to suggest tomei cooling channel as an option in this thread is ridiculous.
if you read properly i didnt suggest tomei cooling pistons to anyone, just comparing. all i am saying is most pistons will have different heat expansion rates, tomei is one brand with the smallest of these (both cooling and non cooling).
You said it was everything to do with the brand, which is not the case at all as I've said - plenty of OTHER brands can also achieve a "slap"less result when the motor is built right. Hell you could build a shit motor and have Tomei's slap as well, wouldnt be hard with some of the motors I've seen built around the place.
End of the day Tomei pistons do not magically achieve something that nobody else has in the realm of piston slap in a cold motor.
yeah and that was in regards to piston slap, you seem to think tomei pistons are way out of everyones budget, i picked up a set for a few hundred dollars more, so why not go the extra? also read up on other forums other then skyaus (in relation to piston slap) and see what you find, it may shock you.....
Must be a combination of design and perhaps a higher silicon content in their pistons inorder to achieve those tight clearances and reduced piston slap.
Do they have some kind of power rating on the pistons?
not too sure ive heard people say 1500hp?
Tomei “cooling channel” are over 3k landed (RRP)
Normal Tomei are around 1800 landed (RRP)
Wiseco or CP (as an example) that come in around 1k-1.2k landed (RRP)
Tell me then please - what exactly do you get for 50% more cost (Tomei standard issue vs Wiseco/CP)?
Just reduced piston slap because of slightly different composition? Come on… Hardly a deal breaker.
Looks to be nothing drastic either way – as I cannot find a detailed spec sheet which would have me believe it’s probably not a lot different to most other pistson on the market, that for which, you can find detailed spec sheets.
Tomei ones don’t magically support another 1000hp, are any less prone to failure or anything else.
If the only thing they can claim is reduce piston movement in the bore due to their composition, then that honestly is not a deal breaker at all when you can have a motor built tight enough these days that piston slap isn’t really an issue.
I'm all for buying the best parts, but you must be mindful of a budget - and this guy is working to a very tight budget. An extra $600 or so when its simply not required, doesn't help him at all.
    • That's awesome. Fully serviced/full log book history for one of those cars is super rare from what I know. With JDM's like Skyline's, Supras, are quite hard to find one with full log book history. S15's seem to be somewhat of an exception, at least the spec s australian delivered models.
    • Hey all, It's been a bit since I have been able to update.  I pulled the fuel pump, first off it was a "universal" pump and the strainer was very clogged, and it was folded over on itself.  I replaced the fuel pump and all is well....  No more stalling.
    • That's convinced me I'll bump up the G30-660 to 770   Any idea if the difference in boost pressure? Cheers
    • When: Saturday 24th of May 2025 - All day Where: Sydney Dragway, Eastern Creek Cost: Varies - Book direct with the GTR Festival Website We will be there on the day with a stand please reach out via our interest form if you wish to help out with the stand. Limited parking will be available in the display area, first in first served with current members getting priority, please register your interest with the link above also. Please post any great photos you take on the day on this thread and we will try use some in our e-mails/website/social media
    • Hey guys so turns out this project is going to be much bigger than I thought haha but I've done some my homework and have done a few panels on my car, but one part I can just not visualise is this. If I do a spot repair and I put filler in a dent for example and sand outside of the repair with 320 grit lets say so the primer can stick as I will only put primer on that repair and the surrounding area and then repaint the whole panel. Don't I need to make sure that I don't put primer on the old clear coat? I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down, it's still shiny. I thought putting paint on clearcoat or primer on clearcoat is a bad idea because it won't stick. So in this scenario it's a bit different to mine but imagine someone doing a spot repair and only painting that small section of repair but the new paint is landing on the old clearcoat. What am I missing?
