  • Replies 181
Might not hurt to post up a list of whats left bro, just copy paste your original list minus the shit sold you've people are too lazy to read through whole thread :P
Free bump.
Edited by Nee-san
Free bump.
Cheers mate, very true
front pipes $100
sunvisors $20 each
interior mirror $20: SOLD
interior lights $40
dash loom $100
interior carpet $70
boot carpet $60: SOLD
heaterbox/ all under dash make an offer: SOLD
rb26 cam/timing belt cover $70
speedo 140,xxxk's $50
brake calipers x 2, $100
intercooler mesh $30
trust pod filters x 2, $80
monster tacho with shift light $50: SOLD
steering wheel $50
GTR fuel pump exc. working order $90
glovebox $30: SOLD
HICAS computer $50 plus have other little computers from throughout the car
have ALL windows except drivers side
rear wiper + motor $40
boot release with fuel flap popper $40
side mirrors $50 each
bonnet squirters $20 pair
bonnet heatshield $60
A,B,C pillars
clutch master $40: SOLD
brake booster $60
accelorator with cable $50 brake and clutch pedals $30 each
steering rack $150: SOLD
metal plate that goes inbetween rear seat and boot $60: SOLD
windscreen wipers $30 pair: SOLD
window wiper motor $40
overflow and washer bottles
kickpanels $20 each
assorted cooler piping from gtr $50
wheelnuts $25
seatbelts
rearseat in mint condition $150
boot rubber seal perfect cond. $40
drivers door window switch $50
rb20 crossover piping $40
turbo timer exc. working order $30: SOLD
handbrake $30
random 8 inch subwoofer never been used $20
Drivers side reverse light: SOLD
O.N.O. on pretty much everything
The problem with posting this list is that there is wayyyyyyyyyyyyyyyy more stuff than this u just gotta ask and i can hook u up.
The entire underside of the car is there except the front calipers, parting out the rear end diff etc.
PM me i'm on here every day.
Some photo's on page 3, i will get more photo's up soon. Cheers
front pipes $80
sunvisors SOLD
interior lights $30
dash loom $100
interior carpet $70
rb26 cam/timing belt cover $60
speedo 140,xxxk's $40
rear end, brakes all there $800
intercooler mesh $20
trust pod filters x 2, $70
steering wheel $40
GTR fuel pump exc. working order $70
glovebox $30: SOLD
boot release with fuel flap popper $20
side mirrors $40 each
bonnet squirters $20 SOLD
A,B,C pillars
brake booster $40
window wiper motor $30
kickpanels $20 each
cooler piping one side $20
wheelnuts full set $10
rear passenger seatbelt $20
rb20 crossover piping $30
handbrake $30
door sills that say skyline $20 each
wheel well cover from in the boot $30
gearbox mount $50
interior door handles $5 each
car loom
1 N1 vent need respray. offers
Front cradle is there still, hubs etc.
final drive shaft
centre console no lid $30
rear bar, haggard suit drift pig
rear boot trim
GT badges $10 each
fuel flap $10
space saver wheel
C Spanners x 2
tailshaft
interior door wiring
wiring from throughout the car just ask
bonnet hinges may be a little bent $20 for both sides
passenger door rubber no rips or leaks $30
Prices adjusted and more stuff added! Pictures for items on request. If there's something u want that u can't see here just PM me, i have heaps more. Everything is O.N.O. and must go. Offers welcome.
Cheers :thumbsup:
front pipes $80
sunvisors SOLD
interior lights $30
dash loom $100
interior carpet $70
steering wheel $40
glovebox $30: SOLD
A,B,C pillars
brake booster $40
kickpanels $20 each
handbrake $30
gearbox mount $50
car loom
final drive shaft
rear boot trim
GT badges $10 each
fuel flap $10
space saver wheel
C Spanners x 2
tailshaft
Cheers :thumbsup:
:yes:
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
