Project Mu - Club Racer V36/370z Rotors Now Available
Hey Guys,
Just been told the new Club Racer rotors we are just unloading from the latest shipment will fit the G37/370z..
( I work for PMU Racing / Project Mu )
We will be fitting them to my G37 this weekend should be a decent upgrade... Will post pics / details once they are fitted!!
The club racer model sits in between Project Mu's SCR and SCR-PRO range of disks and are a massive upgrade on stock, and would be far better than anything currently available here in Australia.
(coupled with a nice set of pads, would be more than suitable for track work)
If your keen to get a set on your car, PM me - we have brought in 3 sets from what i am aware (they are a full front & rear set) and one of those sets is going on my car! haha
-loz
Mods - if this breaks the rules let me know, just figured there might be a few people on here keen since they are new to the market.
PMU_CRD_ROTOR_web.pdf
Edited by loz-tuned
yeah the V35/350z (brembo only) are in the next shipment, ring Racer Industries in around a month for details.
For the V36/370z :
Pricing for these has been set at $1198 for Front & Rear rotors...
For these couple of airfreight sets we will do them at near-cost for $999
Usually we would do this for a newly released product, but they sent us these sets accidently so we just need to move them. (lucky for me lucky for you!) haha
sizing is 355X32 front / 350X20 rear We wont be separating them either : at this price the are only available as a full front-rear set.
Anyone that has bought PMU before knows they are the best brakes out there -there is a reason every winning team in the V8 Supercars, Australian GT, Nascar, JGTC all run PMU Brakes now.
Edited by loz-tuned
When i was looking around the main options i have found for 35/37 are Brembo, Stop-Tech and PMU...
unless you wanted cheapies like DBA or something which are around $750 for a set... Depends what the car is being used for... !
If you wanting to upgrade to some decent pads though you will find the life of some rotors to be very limited.
(ie. Decent PMU Pads such as the HC+ and Club Racer are known to mulch stock rotors very quickly given their compounds, so need to be matched to a decent rotor such as the brembo or PMU)
Right. I am not tracking my V but want to upgrade my brakes (non-brembo) to something else as I need to change the rotors anyway on my next service.
What would you suggest (Brake combo, rotors and pads)? My budget should be around $2k-$3k.
I'm not sure if they are straight bolt up (do your research) but you might be lucky to grab some V36 upgrade calipers from the US - check myg37.com, ebay US or other g owner forums for a upgrade brake kit.
We stock a big brake kit with PMU but they are $4400 for just the fronts, so honestly an OEM Brembo or Akebono upgrade is much better value.
The V36 Akebono's are a big upgrade, and larger than the Brembo and are cheaper since Akebono is a pretty unknown brand to Brembo (but they are awesome)
I would recommend :
Akebono V36 Calipers : $1300 + Shipping
Project Mu Club Spec Rotors : $999
Braided Lines : $99
Decent Fluid: $75
Decent Pads: $500-600 (try and scheme some free pads with the calipers first up though)
Couple of pics of the club spec rotors:
Edited by loz-tuned
 Share
    • shannons wasnt far off what i was paying tbh. so i will check out Lumley and i dont track the car at all. but yer this is definitley a 2020 Nissan Skyline 400R and yer im sure i will have trouble telling my insurance i have a Q50 RS simply because its not the car i have even though its the same build. and yes i did buy it from a dealership.
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
