up for sale is my rb20det that i was going to put in my silvia.
i got a td05 turbo for it, greddy dump pipe, 38mm external gate with screamer pipe!
because i wanted to run some high boost i pulled the head off the motor, cleaned everything, painted all the manifolds,block,sump, etc.
The motor is still pulled down as im waiting on some new camshafts to put it back together, i brought a set off someone on here and they never sent them, i got ripped off!
so i can put the motor back together but you would probably prefer to do it yourself. still sourcing another set of cams though.
i have a brand new genuine timing belt, cam seals,tappet cover gaskets, flywheel bolts, genuine brand new head gasket, ARP HEAD STUDS.
Has a complete wiring loom.
I pulled the motor running from a car, i have everything to bolt it in and get it running.
I want a $1000 for the lot!
I have spent that on parts alone, my loss is your gain.
I also have a s13 silvia rolling shell for sale to drop the motor straight into.
No warranty on anything obviously
Iam located in Newcastle, NSW
Looking for a quick sale so call or text me
Cameron
0415108348
how much are u after for the shell? what condition is it in/whats still on it?
hey mate check out my add for it in the cars for sale section.
there are heaps of pics
hey man do u happen to have a gearbox and rb crossmember? if so how much u after for everything?
i have the crossmember that bolted the rb20 box into a vl commodore, not sure if they are the same crossmember that bolts it into a r32, they are definately very similar.
I can probably get you a rb20 box but it has blown 2nd gear.
$1000 for everything including camshaft which i have now sourced for it.
call me
0415108348
no idea how many k's are on the engine, didnt blow smoke and didnt have any rattles when i pulled it out, bores look okay, hence why i havent touched the bottomend.
I HAVE FOUND THE CAR I WANT TO BUY SO THIS NEEDS TO GO.
$1500 FOR THE SILVIA MENTIONED, CHECK OUT MY TOPICS FOR FULL DETAILS ON IT.
$2000 WITH THE RB20 INCLUDED MINUS TURBO.
I NEED THE CASH THIS WEEK SO I CAN BUY THE CAR SO CALL OR TEXT ME NOW AND MAKE AN OFFER!!!
0415108348
turbo gone
$700 ono for everything else.
make an offer and see what happens, i really need the $$$$$$$$$$
0415108348
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
