According to V35 (japanese magazine) the series2 (Jan03 - Nov04) models sold in Japan when new as follows
350 GT-8 3.66million Yen
350GT 6MT 3.00million Yen
350GT Premium6MT 3.25million Yen
Have no idea what the exchange rate was back then but today it is about 82Yen = $1AUD making them cost between $36k and $46k. No doubt there would be some dealer and rego charges to add but they were not as expensive as you would imagine domestically.
(The autos are far more popular in Japan accounting for 99.5% of the production of these models.)
Unfortunatley, it doesnt work this way.
For whatever reason, there is a big mark up for cars in Australia. Its not just import tax and GST either.
Take a look at the yanks, they pay only $27 - $29k (USD) for a 370z... while we pay $70,000. Work that one out.
So true! Was in the States a in July this year and drove my cousins 335i around LA - when asked how he could afford it, well, it only costs $45,000! (compared to $105k+ out here). I guess Aus is still better than some Asian countries like India, Singapore and even M'sia.
^Diabolique - I was in the US a few weeks back and another reason why Beemers are so affordable is that they were offering 0.9% interest for the life of a loan... If that was the case here I would def consider a 335i
Yeah I think the $70k mark would be realistic. I'm cringing to think how much the V/G coupes will cost when Infiniti hits Australia in a year or 2 (or 3), bearing in mind it is well and truly possible to privately import a base model V36 coupe for somewhere around $35k give or take at the moment.
I recently had to replace my V35 after some fool didn't look where he was going. After the slightly inflated insurance value (agreed value was a good choice) I found myself tantalisingly close to having enough cash to import a V36. Unfortunately when I added up the cost of all the extras I would definitely want (ie the Chris Rogers treatment) I would have been blowing the budget out of the water. In the end I settled for a nice Series 2 V35 for an excellent price, could afford to have all the extras added and still have change from the insurance payout. Its been said many times before but V series coupes are brilliant value :blink:
Edited by MSKYO
And if we want to get even more ludicrous, the famed example is the commodore SS.
Its built here, in australia, and we pay about $50k for virtually the same thing that gets exported to the yanks and they pay only $32k for it.
Anyhow.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
