Does anyone know if you can by a reasonably cheap mechanical Plumbed Fire Extinguisher Kit in aus?
In the UK they sell the following for about 100 pounds + shipping, however they all seem to be reluctant to send outside of the UK (I expect as we probably have different safety standards or something similar).
Mechanical plumbed in fire extinguisher
The cheapest thing through revolution racegear nsw is about 900 just for a canistar.
Anyone one know of similar kits sold in the UK that are available here?
I wouldn't expect they'd ship that standard freight as it's a pressure vessel, i.e, Dangerous Cargo.
In my opinion, you really still need to run a hand held or two, there'd be nothing worse than coming across a burning vehicle and you can do nothing because your fire fighting equipement is permanently installed in your car, 10 ft away but useless.
In fact, in rallying, you still need hand helds even if your car has an installed system for just that reason.
And I couldn't justify the weight of dragging both types around.
+1 to not being able to find anyone to ship a pressurised pressure vessel. When we fly with our paintball tanks (High pressure air ~4500psi), we remove the regulator so there is no chance the tank can hold any pressure.
P.S. http://www.summitracing.com/search/Departm.../?Ns=Rank%7cAsc
No way are you going to buy a "reasonably" priced mechanical plumbed priced one in Aust mate. I have one in my Radical which I would like checked out,,,but even that is pricey. Very few companys are qualified to re-change them here as well.
This revolutions kit is what I have,,,just a different brand but pricing is very reflective of the shit they have to go through.
http://www.revolutionracegear.com.au/index...rimary&CDO=
OH & S and the need for safety data sheets almost prohibit freighting them within this country let alone from overseas,,,which is quite funny because no-one bitches about them installed with the purchase of a car. My car came into the country with nothing said.
Ben's absolutely correct with regard to rallying,,,but if circuit racing is your game,,,head for the nearest marshall,,,rally's little 2 x 1 kilo things are basically only good for maybe getting the two humans safe. They have little to no chance of saving the car in a big one.
Cheers
Neil.
Another supplier just confirmed they won't ship given its a pressurised vessel. It makes sense I just didn't realise it earlier.
I thought it would just be handy to the plumbing into the engine bay for the price they were offering the kit at. Its just an old street car that will see occassional track days.
Given the price it would cost to do this in aus it just isn't worthwhile for my car's useage. Strange as it is a great cheap idea that lots of people are using O/S.
That setup you have Neil looks great and similar to the those UK and US kits just in 4litre size. Unbelievable about the price difference though.
  • 1 year later...
Really?
Wormald / Chubb et al do installations into mobile equipment all the time - must be thousands of installations around the country, ranging up to a couple of hundred grand for some of them. Surely they'd be qualified to service and charge onboard systems. As for their pricing - well I have no idea what they would charge for that service (several grand a pop for mining gear)
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
