Hi All,
i have just completed my rebuild of my RB26 engine, spec are below
the tuner told me that i can't higher the boost due to the injector has already max at 85% or more. if we would to push 1.5 to 1.6 bar the air fuel will lean down. i have attached the dyno sheet.
The question is that i see some of the forumer here have smaller or similar size of injector but could push a much higher WHP.
Is there any problem with my setting or tuning?
RaceTech 86.5 mm piston
TOMEI 1.5mm @ 87mm metal head gasket with oil restrictor
Jun Oil Pump
Balance crank, piston, rod, clutch, main pulley
Refresh Standard Head
HKS step 1 IN/EX 264 cam
Jun Cam gear
BC valve spring
Greddy type 6 throttle intake manifold
SARD 720cc injector
HKS type fuel rail
Tomei Fuel regulator
Garrett GT35R AR1.06 split type
aftermarket ex manifold split type
Tial 44mm ex wastegate
Power FC D Jetro
ETC ETC...
Thank you in advance
DC
https://www.sau.com.au/forums/topic/343175-rb26-720cc-injector-max-out/
Would have thought 720cc capable of quite a bit more power. Pressure on idle is fine but Walbros flow chart shows flow drops off sharply when pressure goes up so I imagine having two of them won't change that. I guess adding an external Bosch 044 or two with a surge tank would solve the problem.-
lol idiot!
