  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
safety...
yeah, thats the other possibility i guess, running to rich and just flooding the plugs so they get clogged easily. Although i would have thought it would be leaning out. Actually Cyrus: why *are* you trying to go above 10psi with stock cooler and stock ECU = badness.. summer will hurt you.
safety...
well this not only happens at over 10psi, on rare occasions it happens around 7-8 psi, under open throttle conditions, meh I dont really want that, be good if I could turn the turbo off for a while as i will be riding to work for a couple weeks seen I want to pay Beau off as fast as possible.
Damn petrol being>$1/ltr, sucks to own a turbo car :P
search function is my freind:
In my opinion the big advantage of the SAFC 11 is the ability to tune part throttle A/F ratios separately from full throttle A/F ratios. With earlier versions the tuner had to compromise, eg; too rich at part throttle to get full throttle OK. This affected fuel economy if you compromised rich and risked engine damage if you compromised lean. With an SAFC 11 you can have a bit of cake and eat it too. Not all the cake though, that's full ECU (as in Power FC) territory.
The SAFC1 's have great extrapolation though, so the lower number of load points is not as big a handicap as some make out.
Skylines run closed loop, therefore if you don't boost the car the AFR's should be 14:1 and won't use much petrol:D
Yeah I am running a turbosmart bleed valve boost controller and after this thursday i am going to turn it down as low as i can go, which is 7psi according to our local hero, i didnt really understand what all this talk about wastegates and dunno really how turbos work, so I didnt argue with him :P
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
