actually erin I was having a similar problem with mine a while ago couldn't figure out what it was. At the top of third full throttle it was as if it was misfiring. Never did figure out what it was. Still has that screaming sound though. Meh I'll get it fixed eventually.
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Charly, I'll let you know what's wrong with mine. I'm hoping it's somehting simple like the fuel being changed. My car never liked running on ultimate in the first place. But i thought I'd try it again. Someone did mention water being in the fuel? or the TPS being sticky. It seems to be ok on WOT, it's just when you are cruising along that it chucks a spaz. It's really annoying me. Feels like I'm actually driving a tractor now.
erin,
my 33's got nothing on my old ca18det silvia for faults. That thing was fu(ked as. It would stall if I ran the aircon. Yes stall driving along at 60kph. I only had it for 10 months and the list of stuff that screwed up on that car was as long as my arm.
My favorite was when the sunroof got jammed open when it was pouring. Sooooo not funny.
I figured the car stuttering thing was my clutch going. might have just been some dodgy fuel as there is nothing wrong with my clutch.
it's been ages since I got on here and whored. The only reason I'm on here is that I really can't be bothered doing any work and I have to wait until at least 6pm before leaving work.
On the upside all the stock I was waiting on has come in this week. Woot.
Sinbad stalls at sets of lights when coming to a stop. The revs just drop and keep dropping till it's stalled.
Somethings seriously wrong here.
:confused: Mine had that problem but I had the stock ecu and a (totally rad sounding) bov with an extremley loose and not adjustable spring. An adjustable plumback one that might I add sounds about 100x less cool fixed that problem.
I really must wind out that spring sometime.
just a question, does this happen when you have the aircon off? or all the time?
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
